1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Stranded-Core (UTP) PVC Bulk
Ethernet Cable - Gray, 1000 ft. (304.8 m), TAA
Highlights
Premium cabling for Category 5
and 5e applications — rated for
350 MHz/1Gbps
communications
4pr Stranded PVC CMR Jacket
MODEL NUMBER: N020-01K-GY
System Requirements
For making patch cables for
Network Installations 1000
Base-T (1Gbps Ethernet),
10/100 Base-T (Ethernet),
100Mbps TPDDI, 155 Mbps
ATM, ISDN, voice and Token
Ring Type 3 applications.
Package Includes
Features
Designed for patch (outside wall) cabling applications
Cabling for category 5 (Cat5) and 5e (Cat5e) applications
Length: 1,000 ft. Color: gray
24 AWG 4-pair stranded UTP cable with PVC CMR jacket
Rated for 350MHz/ 1Gbps communication
Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
ISO/IEC 11801 and ETL (category 5e draft 11)
Available in other lengths
Available in solid copper cable (N022-01K-GY) and in Cat6 (N222-01K and N224-01K)
Specifications
OVERVIEW
UPC Code
037332013057
Technology
Cat5/5e
PHYSICAL
Cable Jacket Color
Gray
Cable Jacket Material
PVC
Cable Jacket Rating
CMR
Cable Shielding
UTP
Cable Outer Diameter (OD)
5.4 mm
1/3
1000-ft. Cat5e Gray Bulk Patch
Cable Stranded PVC 24AWG
350MHz
Cleveland, OH 44122
United States
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
1000
Cable Length (m)
304.88
Cable Length (in.)
12000
Cable Length (cm)
30480
Shipping Dimensions (hwd / in.)
12.99 x 0.50 x 9.45
Shipping Dimensions (hwd / cm)
32.99 x 1.27 x 24.00
Shipping Weight (lbs.)
23.00
Shipping Weight (kg)
10.43
ENVIRONMENTAL
Operating Temperature Range
-4° to 167°F (-20° to 75°C)
Storage Temperature Range
32° to 140°F (0° to 60°C)
COMMUNICATIONS
Bandwidth per TIA Standard
100 MHz
Maximum Bandwidth as Tested
350 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3ab
CONNECTIONS
Side A - Connector 1
BARE WIRE
Side B - Connector 1
BARE WIRE
Crossover Wiring
No
Connector Type
Bare Wire
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA)
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N020-01K-GY”相匹配的价格&库存,您可以联系我们找货
