N222-01K-GY
N222-01K-GY
    TRIPPLITE
    N222-01K-GY
N222-01K-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Solid Core UTP PVC Bulk Ethernet Cable, Gray, 1000 ft. (304.8 m), TAA MODEL NUMBER: N222-01K-GY Highlights ● Meets category 6 cabling standards ● Drastically reduce impedance and structural return loss compared to standard 100Mhz wire ● 4pr Solid Conductor - CMR PVC Jacket System Requirements ● For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications Package Includes ● Features ● Designed for premise (in-wall) cabling applications ● Meets category 6 cabling standards ● Premium cabling for category 6, category 5e and category 5 applications ● Drastically reduce impedance and structural return loss compared to standard 100MHz wire ● High-quality copper wire ● Length: 1000-ft. Color: gray ● 23 AWG 4-pair solid cable with PVC ( CMR ) jacket ● Deliver stable performance up to 550MHz/ 1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) ● Available in plenum cable (N224-01K-GY) Specifications OVERVIEW UPC Code 037332117090 Technology Cat6 PHYSICAL Cable Jacket Color Gray Cable Jacket Material PVC 1/3 1000-ft. Cat6 Gigabit Bulk Solid Gray PVC Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 6.2 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.78 x 14.17 x 13.78 Shipping Dimensions (hwd / cm) 35.00 x 35.99 x 35.00 Shipping Weight (lbs.) 29.50 Shipping Weight (kg) 13.38 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No IP20 Rated No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N222-01K-GY
物料型号:N222-01K-GY 器件简介:超五类千兆位固体芯UTP PVC大卷以太网电缆,灰色,1000英尺(304.8米),符合TAA。
引脚分配:侧A - 连接器1为裸线,侧B - 连接器1为裸线,无交叉布线。
参数特性:超五类电缆,550MHz传输性能,23 AWG 4对固体裸线,PVC CMR外护套,UTP无屏蔽,外径6.2mm。
功能详解:适用于1000 Base-T(1Gbps以太网)、10/100 Base-T(以太网)、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音和令牌环3型应用,以及EIA/TIA应用。
应用信息:设计用于建筑内(墙内)布线应用,大幅减少阻抗和结构性回波损耗。
封装信息:1000英尺的超五类千兆位大卷固体灰色PVC电缆,包装尺寸和重量分别为13.78x14.17x13.78英寸、29.50磅和13.38千克。
N222-01K-GY 价格&库存
很抱歉,暂时无法提供与“N222-01K-GY”相匹配的价格&库存,您可以联系我们找货
