N022-01K-WH
N022-01K-WH
    TRIPPLITE
    N022-01K-WH
N022-01K-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Solid Core (UTP) PVC Bulk Ethernet Cable - White, 1000 ft. (304.8 m), TAA MODEL NUMBER: N022-01K-WH Highlights ● Ideal for all non-plenum horizontal wiring applications ● Rated for 350 MHz/1 Gbps communications ● High-quality 24 AWG 4-pair solid copper wire ● CMR-rated PVC jacket ● Meets IEEE 802.3ab and ANSI/EIA/TIA 568 standards Package Includes ● Premium cabling designed for Cat5/5e premise (in-wall) applications, such as connecting an Ethernet wall jack to a router, patch panel or switch. Features Perfect Solution for Cat5/5e Premise Applications ● Designed for fast transmission and excellent signal quality throughout your LAN ● Delivers speeds up to 350 MHz/1 Gbps ● Ideal for all non-plenum horizontal wiring applications, including 10/100/1000 Base-T Ethernet, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications Premium Construction for Superior Performance ● Made from 24 AWG copper wire ● 4-pair solid UTP ● CMR-rated PVC jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e, draft 11) TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332098429 Technology Cat5/5e 1/3 N022-01K-WH Cat5e 350 MHz Bulk Solid-Core PVC Cable, White, 1000 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 5.1 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 10.63 x 13.78 x 13.78 Shipping Dimensions (hwd / cm) 27.00 x 35.00 x 35.00 Shipping Weight (lbs.) 21.61 Shipping Weight (kg) 9.80 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Antibacterial No IP68 Rated No Snagless Connector No STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N022-01K-WH
物料型号: - MODEL NUMBER: N022-01K-WH
器件简介: - 该产品为Cat5e 350 MHz Solid Core (UTP) PVC Bulk Ethernet Cable,白色,长度为1000英尺(304.8米),符合TAA(贸易协议法案)。
引脚分配: - 连接器类型为裸线(Bare Wire),无交叉线序(Crossover Wiring),无角度连接器(Angled Connector)。
参数特性: - 技术:Cat5/5e - 连接:1/3 - 电缆护套颜色:白色 - 电缆护套材料:PVC - 电缆护套等级:CMR - 电缆屏蔽:UTP(非屏蔽双绞线) - 电缆外径(OD):5.1mm - 导体数量:4对 - 导体材料:纯铜 - 导体规格:24 AWG - 电缆长度:1000英尺(304.88米) - 工作温度范围:-4°F至167°F(-20°C至75°C) - 存储温度范围:32°F至140°F(0°C至60°C) - 带宽:根据TIA标准为100 MHz,测试最大带宽为350 MHz - 网络兼容性:1 Gbps(千兆位)
功能详解: - 适用于Cat5/5e Premise应用,如连接以太网墙插、配线架或交换机。 - 设计用于快速传输和整个局域网中出色的信号质量。 - 提供高达350 MHz/1 Gbps的速度。 - 适用于所有非天花板水平布线应用,包括10/100/1000 Base-T以太网、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音和令牌环3型应用。
应用信息: - 适用于非天花板水平布线应用,包括各种以太网和通信应用。
封装信息: - 电缆长度:1000英尺(304.88米) - 发货尺寸:10.63x13.78x13.78英寸(27.00x35.00x35.00厘米) - 发货重量:21.61磅(9.80千克)
N022-01K-WH 价格&库存
很抱歉,暂时无法提供与“N022-01K-WH”相匹配的价格&库存,您可以联系我们找货
