N022-01K-GY
N022-01K-GY
    TRIPPLITE
    CABLE CAT5E 8COND 24AWG 1000'
N022-01K-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Solid Core (UTP) PVC Bulk Ethernet Cable - Gray, 1000 ft. (304.8 m), TAA Highlights ● Premium cabling for Category 5 and 5e applications — rated for 350 MHz/1Gbps communications ● 4pr Solid - PVC CMR Rated Jacket MODEL NUMBER: N022-01K-GY System Requirements ● For all non-Plenum horizontal premise (in-wall) wiring applications for Network Installations 1000 Base-T (1Gbps Ethernet), 10/100 BaseT (Ethernet), 100Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications. Package Includes ● Features ● Designed for premise (in-wall) cabling applications ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 1000-ft. Color: gray ● 24 AWG 4-pair solid cable with PVC CMR Rated jacket ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other lengths ● Available in stranded copper cable (N020-01K-GY) and in Cat6 (N222-01K and N224-01K) Specifications OVERVIEW UPC Code 037332013071 Technology Cat5/5e PHYSICAL Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 5.1 mm 1/3 1000-ft. Cat5e Gray Bulk Patch Cable Solid PVC 24AWG 350MHz 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 10.63 x 13.78 x 13.78 Shipping Dimensions (hwd / cm) 27.00 x 35.00 x 35.00 Shipping Weight (lbs.) 21.11 Shipping Weight (kg) 9.58 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N022-01K-GY 价格&库存
很抱歉,暂时无法提供与“N022-01K-GY”相匹配的价格&库存,您可以联系我们找货
