N220-01K-BL
N220-01K-BL
    TRIPPLITE
    CAT6GIGABITBULKSTRANDED24AW
N220-01K-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Bulk UTP Stranded 24 AWG CMR PVC Cable, Blue, 1000 ft. (304.8 m) TAA MODEL NUMBER: N220-01K-BL Highlights ● Less impedance and structural return loss than 100 MHz wire ● Channel-tested to 250 MHz/1 Gbps communications ● High-quality 24 AWG 4-pair stranded copper wire ● CMR-rated PVC jacket ● Meets IEEE 802.3ab and ANSI/EIA/TIA 568 standards Package Includes ● Premium high-speed cabling designed for creating custom-length Cat6 patch cables. Features Perfect Solution for High-Speed Cat6 Premise Applications ● Designed for do-it-yourself custom patch cable assemblies ● Delivers speeds up to 250 MHz/1 Gbps ● No center spline and overall 0.22 in. diameter makes for easy RJ45 plug termination ● Reduces impedance and structural return loss compared to standard 100 MHz wire ● Ideal for 10/100/1000 Base-T Ethernet, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, EIA/TIA and Token Ring Type 3 applications Premium Construction for Superior Performance ● Made from 24 AWG copper wire (7 x 32 AWG per conductor) ● 4-pair stranded UTP ● Minimum near-end crosstalk ● CMR-rated PVC jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6, draft 11) TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332196552 1/3 N220-01K-BL Cat6 Gigabit Bulk Stranded 24 AWG CMR PVC Cable, Blue, 1000 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 5.6 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 11.20 x 13.40 x 13.00 Shipping Dimensions (hwd / cm) 28.45 x 34.04 x 33.02 Shipping Weight (lbs.) 23.00 Shipping Weight (kg) 10.43 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N220-01K-BL
1. 物料型号: - 型号:N220-01K-BL - 描述:Cat6 Gigabit Bulk UTP Stranded 24 AWG CMR PVC Cable, Blue, 1000 ft.(304.8 m)
2. 器件简介: - 该产品是一种Cat6级别的高速网络电缆,采用24 AWG绞合铜线,CMR级PVC外皮,无中心脊柱设计,便于RJ45插头端接,提供高达250 MHz/1 Gbps的传输速度。
3. 引脚分配: - 连接器A和B均为裸线,无交叉线序,即直通线。
4. 参数特性: - 技术:Cat6 - 连接:直通线序,无交叉线序 - 物理特性:蓝色PVC外皮,CMR等级,UTP无屏蔽,外径5.6mm,4对绞合铜线,24 AWG规格 - 电缆长度:1000英尺(304.88米) - 操作温度范围:-4°F至167°F(-20°C至75°C) - 存储温度范围:32°F至140°F(0°C至60°C) - 带宽:根据TIA标准为250 MHz,测试最大带宽为500 MHz - 网络兼容性:支持1 Gbps(千兆位)
5. 功能详解: - 适用于10/100/1000 Base-T以太网、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音、EIA/TIA和令牌环类型3应用。 - 由24 AWG铜线(每导体7x32 AWG)构成,4对绞合UTP,最小近端串扰。
6. 应用信息: - 适用于高速Cat6场所应用,适合自制定制长度的Cat6跳线。
7. 封装信息: - 包装包括N220-01K-BL Cat6 Gigabit Bulk Stranded 24 AWG CMR PVC Cable,蓝色,1000英尺。 - 发货尺寸和重量:11.20x13.40x13.00英寸,23.00磅;28.45x34.04x33.02厘米,10.43千克。
N220-01K-BL 价格&库存
很抱歉,暂时无法提供与“N220-01K-BL”相匹配的价格&库存,您可以联系我们找货
