N024-01K
N024-01K
    TRIPPLITE
    CABLE CAT5E 8COND 24AWG 1000'
N024-01K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Bulk Solid Core Plenum-Rated Cable, Blue, 1000-ft. Highlights ● Premium cabling for Category 5 and 5e applications — rated for 350 MHz/1Gbps communications ● 4pr Solid - Blue Plenum CMP Rated Jacket ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N024-01K System Requirements ● For premise (in-wall) cabling applications in air ducts and dropped ceilings for Network Installations 1000 Base-T (1Gbps Ethernet), 10/100 BaseT (Ethernet), 100Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications. Package Includes ● Description Tripp Lite's 1,000-ft. category 5e (Cat5e) solid Blue plenum bulk cable is designed for premise (in-wall) cabling applications in air ducts and drop ceilings. This 24 AWG 4-pair solid cable has a plenum jacket and is rated for 350MHz/1Gbps communication. Transition speed up to 100 Mbps, 10 Mbps, 10base-t and Ethernet systems up to 100 Mbps. Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e, draft 11). Features ● Designed for premise (in-wall) cabling applications in air ducts and drop ceilings ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 1,000 ft. ● 24 AWG 4-pair solid cable with smoke resistant Blue plenum (CMP) jacket ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in stranded copper cable (N020-01K-GY), in solid PVC cable (N022-01K) and in Cat6 (N22201K and N224-01K) ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332013118 Technology Cat5/5e 1/2 1,000 ft. Cat5e Bulk Patch Cable Solid Blue Plenum 24AWG 350MHz 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Blue Cable Jacket Rating CMP Cable Shielding UTP Wire Type Solid Wire Gauge (AWG) 24 Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.20 x 10.20 x 13.40 Shipping Dimensions (hwd / cm) 33.53 x 25.91 x 34.04 Shipping Weight (lbs.) 19.40 Shipping Weight (kg) 8.80 COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE FEATURES & SPECIFICATIONS Snagless Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N024-01K 价格&库存
很抱歉,暂时无法提供与“N024-01K”相匹配的价格&库存,您可以联系我们找货
