N223-01K-BL
N223-01K-BL
    TRIPPLITE
    N223-01K-BL
N223-01K-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G-Certified Solid Core UTP CMR PVC Bulk Ethernet Cable, Blue, 1000 ft. (304.8 m) MODEL NUMBER: N223-01K-BL Highlights ● Rated for 10 Gbps communications ● High-quality 23 AWG 4-pair solid copper wire, UnShielded ● Flame-retardant unshielded CMR-rated PVC jacket ● Compliant with RoHS ● Meets IEEE 802.3, TIA 568-C.2 and ISO/IEC 11801 standards Package Includes ● Premium high-speed cabling designed for Cat6a premise (in-wall) applications that allow CMR-rated PVC jackets, such as data centers where 10GBase-T communication is essential. Features Perfect Solution for High-Speed Cat6a Premise Applications ● Ideal for data centers where local code allows CMR-rated PVC jackets and 10GBase-T communication is essential ● Delivers speeds up to 10 Gbps ● Ideal for 10/100/1000 Base-T Ethernet applications Premium Construction for Superior Performance ● Made from 23 AWG copper wire ● 4-pair solid Unshielded UTP ● Minimum near-end crosstalk and ANEXT ● Flame-retardant unshielded CMR-rated PVC jacket ● Meets most current industry standards, including RoHS, IEEE 802.3, ANSI/EIA/TIA 568 and ISO/IEC 11801 Specifications OVERVIEW UPC Code 037332181787 Technology Cat6a PHYSICAL Cable Jacket Color Blue 1/3 N223-01K-BL Cat6a 10G Bulk Solid-Core 4-Pair Unshielded PVC / CMR Cable, Blue, 1000 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 7.6 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 12.90 x 9.50 x 9.50 Shipping Dimensions (hwd / cm) 32.77 x 24.13 x 24.13 Shipping Weight (lbs.) 49.00 Shipping Weight (kg) 22.23 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 500 MHz Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N223-01K-BL
物料型号: - MODEL NUMBER: N223-01K-BL
器件简介: - 该产品是一款Cat6a 10G认证的实心铜芯UTP CMR PVC室外以太网电缆,蓝色,长度为1000英尺(304.8米)。 - 采用高品质的23 AWG 4对实心铜线,未屏蔽。 - 具有阻燃特性的CMR级PVC外皮。 - 符合RoHS标准,满足IEEE 802.3、TIA 568-C.2和ISO/IEC 11801标准。
引脚分配: - Side A - Connector 1: BARE WIRE(裸线) - Side B - Connector 1: BARE WIRE(裸线)
参数特性: - 技术:Cat6a - 电缆外皮颜色:蓝色 - 电缆外皮材料:PVC - 电缆外皮等级:CMR - 电缆屏蔽:UTP(非屏蔽) - 电缆外径(OD):7.6毫米 - 导体数量:4对 - 导体材料:实心铜 - 导体规格:23 AWG - 电缆长度:1000英尺(304.88米) - 操作温度范围:-4°至167°F(-20°至75°C) - 存储温度范围:32°至140°F(0°至60°C) - 带宽:每TIA标准500 MHz,测试最大带宽600 MHz - 网络兼容性:10 Gbps - 支持的IEEE标准:802.3ab
功能详解: - 该电缆是高速Cat6a应用的完美解决方案,尤其适用于数据中心等需要CMR级PVC外皮和10GBase-T通信的场合。 - 提供高达10 Gbps的速度,适合10/100/1000 Base-T以太网应用。
应用信息: - 该电缆设计用于Cat6a布线系统(室内),适用于允许CMR级PVC外皮的数据中心,其中10GBase-T通信至关重要。
封装信息: - 包装包括:N223-01K-BL Cat6a 10G Bulk Solid-Core 4-Pair Unshielded PVC / CMR Cable,蓝色,1000英尺。
N223-01K-BL 价格&库存
很抱歉,暂时无法提供与“N223-01K-BL”相匹配的价格&库存,您可以联系我们找货
