N224-01K-GN
N224-01K-GN
    TRIPPLITE
    CABLECAT64PR24AWGGRN1000'
N224-01K-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Solid Core Plenum-Rated UTP CMP PVC Bulk Ethernet Cable, Green, 1000 ft. (304.8 m) MODEL NUMBER: N224-01K-GN Highlights ● Ideal for horizontal applications in air ducts and drop ceilings ● Rated for 550 MHz/1 Gbps communications ● High-quality 23 AWG 4-pair solid copper wire ● Plenum-rated CMP jacket ● Meets IEEE 802.3ab and ANSI/EIA/TIA 568 standards Package Includes ● Premium high-speed cabling designed for Cat6 premise (in-wall) applications in air ducts and drop ceilings, such as the distribution of data, voice and digital video across Gigabit Ethernet networks. Features Perfect Solution for High-Speed Cat6 Premise Applications in Air Ducts and Drop Ceilings ● Designed for distributing data, voice and digital video across Gigabit Ethernet networks ● Delivers speeds up to 550 MHz/1 Gbps ● Ideal for horizontal wiring applications, including 10/100/1000 Base-T Ethernet, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, EIA/TIA and Token Ring Type 3 applications Premium Construction for Superior Performance ● Made from 23 AWG copper wire ● 4-pair solid UTP ● Minimum near-end crosstalk ● Plenum-rated CMP jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6, draft 11) Specifications OVERVIEW UPC Code 037332159991 Technology Cat6 PHYSICAL 1/3 N224-01K-GN Cat6 Gigabit Bulk Solid-Core Plenum-Rated CMP Cable, Green, 1000 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Green Cable Jacket Material PVC Cable Jacket Rating CMP Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.78 x 14.17 x 13.78 Shipping Dimensions (hwd / cm) 35.00 x 35.99 x 35.00 Shipping Weight (lbs.) 31.00 Shipping Weight (kg) 14.06 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Snagless Connector No STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N224-01K-GN
物料型号:N224-01K-GN
器件简介: - Tripp Lite系列的Cat6 Gigabit Solid Core Plenum-Rated UTP CMP PVC Bulk Ethernet Cable,长度为1000英尺(约304.8米),颜色为绿色。 - 该电缆适用于水平应用,如空气管道和吊顶中,支持550 MHz/1 Gbps通信。
引脚分配: - 连接器类型为裸线(Bare Wire),没有交叉线(Crossover Wiring)。 - 侧A和侧B的连接器1均为裸线。
参数特性: - 技术:Cat6 - 物理特性:绿色PVC护套,CMP评级,UTP屏蔽,外径6.0毫米,4对23 AWG实心铜导体。 - 电缆长度:1000英尺(304.88米)。 - 运输尺寸和重量:具体数值在文档中给出。
功能详解: - 适用于高速Cat6场所应用,如空气管道和吊顶中的数据、语音和数字视频分配。 - 支持高达550 MHz/1 Gbps的速度,适用于10/100/1000 Base-T以太网等多种应用。 - 由23 AWG铜线制成,4对实心UTP,符合多种行业标准,如IEEE 802.3ab等。
应用信息: - 适用于水平布线应用,包括10/100/1000 Base-T以太网、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音、EIA/TIA和令牌环类型3应用。
封装信息: - 电缆护套材料:PVC - 电缆护套颜色:绿色 - 电缆护套评级:CMP - 电缆屏蔽:UTP(非屏蔽双绞线) - 导体材料:实心铜 - 导体规格:23 AWG
N224-01K-GN 价格&库存
很抱歉,暂时无法提供与“N224-01K-GN”相匹配的价格&库存,您可以联系我们找货
