N224-01K-GY
N224-01K-GY
    TRIPPLITE
    N224-01K-GY
N224-01K-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Solid Core Plenum-Rated UTP CMP PVC Bulk Ethernet Cable, Gray, 1000 ft. (304.8 m) Highlights ● Premium cabling for Category 6, Category 5e and Category 5 applications-rated for 550 MHz/1 Gbps communications ● Designed to meet Category 6 specifications: reduces crosstalk and return loss ● IEEE 802.3ab ● 1,000ft Box PLENUM ( CMP ) 4pair Solid UTP ● Designed for premise (in-wall) cabling applications in air ducts and drop ceilings ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N224-01K-GY System Requirements ● Features ● Designed for premise (in-wall) cabling applications in air ducts and drop ceilings ● Premium cabling for category 6, category 5e and category 5 applications ● Color: Gray / Length: 1000-ft. ● 24 AWG 4-pair solid cable with Gray Plenum ( CMP ) jacket ● Deliver stable performance up to 550MHz/ 1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) ● Available in PVC cable as well (N222-01K-GY and N222-01K-BL) ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes ● Specifications OVERVIEW UPC Code 037332117083 Technology Cat6 PHYSICAL Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating CMP Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications. 1/3 1000-ft. Cat6 Gigabit Bulk 4PR Solid Plenum CMP Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 1000 Cable Length (m) 304.88 Cable Length (in.) 12000 Cable Length (cm) 30480 Shipping Dimensions (hwd / in.) 13.78 x 14.17 x 13.78 Shipping Dimensions (hwd / cm) 35.00 x 35.99 x 35.00 Shipping Weight (lbs.) 31.00 Shipping Weight (kg) 14.06 ENVIRONMENTAL Operating Temperature Range -4° to 167°F (-20° to 75°C) Storage Temperature Range 32° to 140°F (0° to 60°C) COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab CONNECTIONS Side A - Connector 1 BARE WIRE Side B - Connector 1 BARE WIRE Crossover Wiring No Connector Type Bare Wire Angled Connector No FEATURES & SPECIFICATIONS Antibacterial No IP68 Rated No Snagless Connector No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; IEEE 802.3ab 1000Base-T; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N224-01K-GY
物料型号: - 型号编号:N224-01K-GY
器件简介: - 这是一卷Cat6 Gigabit级别的以太网电缆,适用于千兆位以太网、10/100 Base-T以太网、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音和令牌环类型3应用以及EIA/TIA应用。 - 该电缆设计用于建筑内部(如墙壁内)布线,可在空气管道和吊顶中使用。
引脚分配: - 连接器1(Side A)和连接器1(Side B)均为裸线(BARE WIRE),不支持交叉布线(Crossover Wiring),连接器类型为裸线(Bare Wire),没有直角连接器(Angled Connector)。
参数特性: - 技术:Cat6 - 长度:1000英尺(约304.8米) - 线规:24 AWG 4对实心线 - 外被材料:灰色Plenum(CMP)套管 - 性能:提供高达550MHz/1Gbps的稳定通信性能 - 符合标准:ISO/IEC 11801和ETL(Cat6草案11),满足当前大多数行业标准,包括IEEE 802.3ab、IEEE 802.5、ANSI/EIA/TIA 568
功能详解: - 适用于建筑内部布线,如空气管道和吊顶。 - 高品质Cat6、Cat5e和Cat5应用的电缆。 - 提供稳定的550MHz/1Gbps通信性能。 - 符合联邦贸易协定法案(TAA),适用于GSA计划购买。
应用信息: - 适用于1000 Base-T(1Gbps以太网)、10/100 Base-T(以太网)、100 Mbps TPDDI、155 Mbps ATM、ISDN、语音和令牌环类型3应用以及EIA/TIA应用。
封装信息: - 包装包括1000英尺Cat6 Gigabit Bulk 4PR实心Plenum CMP电缆。 - UPC代码:037332117083
N224-01K-GY 价格&库存
很抱歉,暂时无法提供与“N224-01K-GY”相匹配的价格&库存,您可以联系我们找货
