09456000101
09456000101
    HARTING(浩亭)
09456000101 数据手册
HARTING PROFINET Type C Cable 4-wire, Cat. 5, PUR PROFINET Type C Cable 4-wire, Cat. 5, PUR Advantages • • • • General Suitable for PROFINET cabling Category 5 / Class D according to ISO/IEC 11801 respectively EN 50173-1 and ISO/IEC 24702 respectively EN 50173-3 Capable for drag line Applicable for industrial premises RoHS conform, UL listed, flame retardant, halogen free Description This data cable is suitable for PROFINET cabling according to type C in industrial premises and areas. It is useable for flexible cords especially dragline. The core is fitted with 4 wires twisted to quad that allows the transmission of Fast Ethernet 10/100Mbit/s. It is designed for fast assembling with the easystripping tool and can be assembled with all HARTING 4-pole RJ45 connectors. Order number PROFINET Type C Cable 4-wire, Cat. 5, PUR 20 50 100 500 m ring m ring m ring m reel 09 45 600 0131 09 45 600 0141 09 45 600 0101 09 45 600 0111 • • • • • Wire: Stranded tinned copper AWG 22/7 Insulation: : PE ∅ 1.5 mm (+0.024/ 0.036) Inner sheath: Thermoplastic copolymer (FRNC) Overall screen: Aluminate foil overlapped, tinned copper wire braid, braid coverage about 85% Outer sheath: Polyurethane (PUR), flame retardant Color code: wh, ye, bu, or Color of inner sheath: white Color of outer sheath: green, RAL 6018 Overall diameter: 6.3 mm – 6.7 mm All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. AWi 21.11.2007 HARTING PROFINET Type C Cable 4-wire, Cat. 5, PUR Technical Characteristics Performance Category 5 according to EN 50288-2-1:2003, IEC 61156-5:2002 Mechanical Characteristics Minimal bending radius Pull force Trailing cable Torsion strength During installation: 7 x diameter After installation: 3 x diameter max. 150 N 3 million bending cycles bending diameter 200 mm at a speed of 4 m/s acceleration 4 m/s² +/-180° on 1m, 30 thousand cycles Electrical Characteristics at 20°C Surface transfer impedance at 10 MHz Loop resistance Insulation resistance Signal runtime Characteristic impedance at 100 MHz Test voltage (wire/wire/screen rms 50Hz 1min) 20 mOhm/m max. 120 Ohm/km min. 500 MOhm*km 5.3 ns/m 100 Ohm +/- 5 Ohm 2000V Chemical Characteristics Flame retardant Free of hazardous substances Oil resistance UV-resistant IEC 60332-1-2 RoHS 2002/95/EG EN 60811-2-1 Thermal Characteristics Permissible temperature range During laying - 40° C to + 70° C - 20° C to + 60° C Printing HARTING INDUSTRIAL ETHERNET TRAILING CABLE CAT 5 PLUS * 22AWG (SHIELDED) (UL) E119100 VERIFIED CAT 5E PATCH CABLE CMX 75°C FRNC * 094560001010100 "sequential length in meters" * "year/internal order number" "HARTING-LOGO" Weight about 61 kg/km All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. AWi 21.11.2007 HARTING PROFINET Type C Cable 4-wire, Cat. 5, PUR Technical Characteristics Frequency MHz Attenuation dB/100m NEXT dB typ. Cat 5 max* typ. Cat 5 min* 1 2.1 2.1 80 65.3 4 4 4.0 76 56.3 10 6.3 6.3 70 50.3 16 8 8.0 65 47.2 20 9 9.0 63 45.8 31.25 11.4 11.4 60 42.9 62.5 16.5 16.5 55 38.4 100 21.3 21.3 50 35.3 * EN 50288-2-1:2003 All data given are in line with the actual state of art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. AWi 21.11.2007
09456000101 价格&库存
很抱歉,暂时无法提供与“09456000101”相匹配的价格&库存,您可以联系我们找货
  • 1+3920.32020
库存:800
