166-90190
166-90190
    HELLERMAN(海尔曼太通)
    HOSE0.47"IDPOLY100'BLACK
166-90190 数据手册
166-90190 Article Number: 166-90190 Description: HelaGuard Non-Metallic Conduit, Std. Weight, 0.38" Dia, Nylon PA6, Black, 100 ft/reel Base Data Local Order Number 166-90190 Type HG-SW0380 Color Black (BK) Features and benefits ‡Material is easy to use and cut; reduces installation time and labor costs. ‡Flexible, abrasion resistant and durable for a variety of applications. ‡Good impact strength; recovers quickly if crushed. ‡UV resistant; suitable for use in outdoor applications. ‡Offered in fine or course corrugated pitch. Quantity Per reel Product Description A standard weight corrugated conduit made of PA6 nylon that offers flexible abrasion protection for wire and cable bundles. Easy to cut and use, the material is highly resistant to solvents and oils. Combine with HelaGuard non-metallic fittings for IP66 rating or greater protection against water, wind and dirt. Short Description HelaGuard Non-Metallic Conduit, Std. Weight, 0.38" Dia, Nylon PA6, Black, 100 ft/reel Length L (Imperial) 100.0ft Length L (Metric) 30.5m Inner Diameter D (Imperial) 0.47" Inner Diameter D (metric) 11.8mm Euro (NW) Size 12mm Pitch Type F (Fine) Trade Size 3/8 " Outside Diameter D (imperial) 0.63" Outside Diameter D (metric) 15.8mm Nominal Diameter (Imperial) 3/8" Nominal Diameter (Metric) 16mm Inside Bend Radius (Imperial) 1.38" Inside Bend Radius (Metric) 35mm Product Dimensions generated on: 5/10/2017 166-90190 Material and Specifications Material Polyamide 6 (PA6) Material Shortcut PA6 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -40°F to +248°F (-40°C to +120°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 100ft Package Quantity (Metric) 30.5m Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90190 价格&库存
很抱歉,暂时无法提供与“166-90190”相匹配的价格&库存,您可以联系我们找货
