VGAG.02BK100
VGAG.02BK100
    TECHFLEX
    SLEEVING0.258"IDFBRGLASS100'
VGAG.02BK100 数据手册
ADVANCED ENGINEERING Technical Data Sheet Rated to 266°F Class H (130°C) Vinyl Coated Fiberglass Sleeving Grade A, B, & C Grade A (8,000 V) Mil-I-3190/2 VINYL FLEX GLASS (VG) sleeving is a heat-treated, tightly braided fiberglass sleeving coated with a firmly bonded plasticized polyvinylchloride film. This durable sleeving will withstand mechanical stress and holds it dielectric strength on all bends. Grade B (4,000 V) ELECTRICAL INSULATION Technical Data Sheet Grade C (2,500 V) Cut and Abrasion Resistant Excellent Low Temp. Flexibility Vinyl Flex Glass is used for supplementary insulation on transformer, motor, generator, and resistor leads. Also other applications include television, radio, and other electric circuits where it can be pushed back to permit soldering. Highly resistant to acids and solvents, and will withstand tough assembly handling. The Vinyl compound is designed for continuous operation at 130°C temperatures, while providing excellent abrasion and cut-through resistance. Colors Available: WH, YL, & BK Colors Available: Cut Cleanly Scissors Material Vinyl Coated Fiberglass Grade A, B, & C www.techflex.com 1 (833) SLEEVING • 973.300.9242 • fax: 973.300.9409 104 Demarest Road • Sparta, NJ 07871 White (WH), Yellow (YL), & Black (BK) ELECTRICAL ADVANCEDINSULATION ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups Diameter Part# Grade Part# Grade Part# Grade Bulk Spool Shop Spool 24 22 20 18 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 3/8” 7/16” 1/2” 5/8” 3/4” 7/8” 1” 0.020” 0.025” 0.032” 0.040” 0.053” 0.057” 0.064” 0.072” 0.081” 0.091” 0.102” 0.114” 0.129” 0.144” 0.162” 0.182” 0.204” 0.229” 0.258” 0.289” 0.325” 0.375” 0.438” 0.500” 0.625” 0.750” 0.875” 1.000” VGAG.24 VGAG.22 VGAG.20 VGAG.18 VGAG.16 VGAG.15 VGAG.14 VGAG.13 VGAG.12 VGAG.11 VGAG.10 VGAG.09 VGAG.08 VGAG.07 VGAG.06 VGAG.05 VGAG.04 VGAG.03 VGAG.02 VGAG.01 VGAG.00 VGA0.38 VGA0.44 VGA0.50 VGA0.63 VGA0.75 VGA0.88 VGA1.00 A A A A A A A A A A A A A A A A A A A A A A A A A A A A VGBG.24 VGBG.22 VGBG.20 VGBG.18 VGBG.16 VGBG.15 VGBG.14 VGBG.13 VGBG.12 VGBG.11 VGBG.10 VGBG.09 VGBG.08 VGBG.07 VGBG.06 VGBG.05 VGBG.04 VGBG.03 VGBG.02 VGBG.01 VGBG.00 VGB0.38 VGB0.44 VGB0.50 VGB0.63 VGB0.75 VGB0.88 VGB1.00 B B B B B B B B B B B B B B B B B B B B B B B B B B B B VGCG.24 VGCG.22 VGCG.20 VGCG.18 VGCG.16 VGCG.15 VGCG.14 VGCG.13 VGCG.12 VGCG.11 VGCG.10 VGCG.09 VGCG.08 VGCG.07 VGCG.06 VGCG.05 VGCG.04 VGCG.03 VGCG.02 VGCG.01 VGCG.00 VGC0.38 VGC0.44 VGC0.50 VGC0.63 VGC0.75 VGC0.88 VGC1.00 C C C C C C C C C C C C C C C C C C C C C C C C C C C C 500’ 500’ 500’ 500’ 500’ 500’ 500’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ Available Colors WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, YL, BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK BK RATE OF BURNING Conforms with requirements of NEMA TF-1, MIL-I-3190/3, and ASTM D372. CHEMICAL RESISTANCE Resistant to oils, acids, alkalies and most organic solvents. After more than 168 hours in the most commonly used aromatics, xylene and toluene, the dried sleeving substantially regains its original properties. LOW TEMPERATURE Bends without cracking at -25°C/-13°F. © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-06 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Nominal Size
VGAG.02BK100 价格&库存
很抱歉,暂时无法提供与“VGAG.02BK100”相匹配的价格&库存,您可以联系我们找货
