166-90197
Article Number:
166-90197
Description:
HelaGuard Non-Metallic Conduit, Light Weight, 0.50" Dia,
PA6, Black, 100 ft/Std. Reel
Base Data
Local Order Number
166-90197
Type
HG-LW0500
Color
Black (BK)
Features and benefits
Lightweight and highly flexible for use in tight bend and fit applications.
Easy to use and cut; reduces installation time and labor costs.
Good abrasion resistance and impact strength; recovers quickly if crushed.
Offered in fine or course corrugated pitch.
Quantity Per
reel
Product Description
Lightweight nylon corrugated conduit provides high flexibility and good mechanical
protection of wire and cable bundles, especially useful in smaller bend radius tight-fit
applications. PA6 material offers high resistance to oils and solvents, along with
good abrasion protection. Combine with HelaGuard non-metallic fittings for IP66
rating or greater protection against water, wind and dirt.
Short Description
HelaGuard Non-Metallic Conduit, Light Weight, 0.50" Dia, PA6, Black, 100 ft/Std.
Reel
Length L (Imperial)
100.0ft
Length L (Metric)
30.5m
Inner Diameter D (Imperial)
0.67"
Inner Diameter D (metric)
16.7mm
Euro (NW) Size
17mm
Pitch Type
F (Fine)
Trade Size
1/2 "
Outside Diameter D (imperial)
0.84"
Outside Diameter D (metric)
21.2mm
Nominal Diameter (Imperial)
1/2"
Nominal Diameter (Metric)
21mm
Inside Bend Radius (Imperial)
1.58"
Inside Bend Radius (Metric)
40mm
Product
Dimensions
generated on:
5/10/2017
166-90197
Material and
Specifications
Material
Polyamide 6 (PA6)
Material Shortcut
PA6
Flammability
self-extinguishing according to EN IEC 61386
Halogenfree
Yes
Operating Temperature
-40°F to +248°F (-40°C to +120°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
100ft
Package Quantity (Metric)
30.5m
Customs Number(Schedule B)
3926909987
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90197”相匹配的价格&库存,您可以联系我们找货
