166-90199
166-90199
    HELLERMAN(海尔曼太通)
166-90199 数据手册
166-90199 Article Number: 166-90199 Description: HelaGuard Non-Metallic Conduit, Light Weight, 1.00" Dia, PA6, Black, 50 ft/Std. Reel Base Data Local Order Number 166-90199 Type HG-LW1000 Color Black (BK) Features and benefits ‡Lightweight and highly flexible for use in tight bend and fit applications. ‡Easy to use and cut; reduces installation time and labor costs. ‡Good abrasion resistance and impact strength; recovers quickly if crushed. ‡Offered in fine or course corrugated pitch. Quantity Per reel Product Description Lightweight nylon corrugated conduit provides high flexibility and good mechanical protection of wire and cable bundles, especially useful in smaller bend radius tight-fit applications. PA6 material offers high resistance to oils and solvents, along with good abrasion protection. Combine with HelaGuard non-metallic fittings for IP66 rating or greater protection against water, wind and dirt. Short Description HelaGuard Non-Metallic Conduit, Light Weight, 1.00" Dia, PA6, Black, 50 ft/Std. Reel Length L (Imperial) 50.0ft Length L (Metric) 15.2m Inner Diameter D (Imperial) 1.12" Inner Diameter D (metric) 28.1mm Euro (NW) Size 29mm Pitch Type C (Coarse) Trade Size 1" Outside Diameter D (imperial) 1.36" Outside Diameter D (metric) 34.5mm Nominal Diameter (Imperial) 1" Nominal Diameter (Metric) 34mm Inside Bend Radius (Imperial) 2.17" Inside Bend Radius (Metric) 55mm Product Dimensions generated on: 5/10/2017 166-90199 Material and Specifications Material Polyamide 6 (PA6) Material Shortcut PA6 Flammability self-extinguishing according to EN IEC 61386 Halogenfree Yes Operating Temperature -40°F to +248°F (-40°C to +120°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 50ft Package Quantity (Metric) 15.2m Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90199
- 物料型号: 166-90199 - 产品描述: HelaGuard非金属电缆保护管,轻质,直径1.00英寸,PA6材质,黑色,50英尺标准卷装。 - 产品特点: 轻质、高柔韧性,适用于狭窄弯曲和安装环境;易于使用和切割,减少安装时间和劳动成本;良好的耐磨损性和抗冲击性;如果被压碎,能快速恢复;提供精细或粗糙的波纹间距。 - 参数特性: 材料为聚酰胺6(PA6),具有自熄性,符合EN IEC 61386标准;无卤素;工作温度范围为-40°F至+248°F(-40°C至+120°C);符合ROHS标准;在美国和加拿大获得UL认可。 - 功能详解: 提供高柔韧性和良好的机械保护,特别适用于较小弯曲半径的紧密安装应用;PA6材料提供高耐油和耐溶剂性,以及良好的耐磨损保护。 - 应用信息: 与HelaGuard非金属配件结合使用,可达到IP66或更高等级的防水、防风和防尘保护。 - 封装信息: 标准卷装长度为50英尺(15.2米),内径为1.12英寸(28.1毫米),外径为1.36英寸(34.5毫米)。
166-90199 价格&库存
很抱歉,暂时无法提供与“166-90199”相匹配的价格&库存,您可以联系我们找货
