ADVANCED ENGINEERING
HEAVY DUTY
Technical Data Sheet
Put-Ups
R
esists Snagging
P
revents Damage From UV,
Gasoline, Engine Chemicals
And Salt
R
esists Cut, Abrasion And
Penetration
F
lexible & Economical
General Purpose Protection
D
eflects High Pressure Hose
Ruptures
C
ustom Lengths Available
Nominal
Size
Part
Wall
Thickness
Maxi
Coil
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
0.71”
0.83”
0.92”
1.00”
1.13”
1.25”
1.34”
1.59”
1.75”
2.07”
2.38”
2.54”
2.86”
3.34”
3.66”
DFN0.71BK
DFN0.83BK
DFN0.92BK
DFN1.00BK
DFN1.13BK
DFN1.25BK
DFN1.34BK
DFN1.59BK
DFN1.75BK
DFN2.07BK
DFN2.38BK
DFN2.54BK
DFN2.86BK
DFN3.34BK
DFN3.66BK
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
.045”
300’
300’
300’
300’
300’
300’
300’
300’
300’
300’
300’
300’
300’
300’
300’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
25’
25’
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
2.57
2.58
3.22
3.66
4.18
4.49
4.84
5.37
6.13
7.26
8.28
8.98
9.89
11.59
12.25
Industrial Hose And Cable
Protection For Harsh Environments
The tightly woven nylon makes DF the
perfect solution for hose & cable protection.
The .045 inch wall thickness will protect cables,
hoses and ropes from weather, sunlight and
abrasion damage.
Cut Cleanly
Scissors
Material
Nylon
Colors Available:
Black (BK)
When installed over uncoated cable or chains,
DF will prevent scraping, chafing and contact
damage to painted or other fragile surfaces.
DF is resistant to chemicals, UV damage and rot,
and is suitable for continuous outdoor use under
all weather conditions.
The flexible sleeving cuts with a scissor and the
tight construction slides easily over any application.
Grade
DFN
Wall Thickness
.045”
This is a non-expandable product. Be sure to
match your application diameter accurately.
Drawing Number
TF001DF-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
ISO
6945
MSHA
HEAVY
DUTY ENGINEERING
ADVANCED
Melt Point
ASTM D-2117
ABRASION
410°F (210°C)
Mil-I-23053
Very High
248°F (120°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
70%
Visible Wear And Some
Pulling Of Fibers
500 Test Cycles
Further Wear And Some
Pulling At Seam
550 Test Cycles
Material Wearing
Through At Seam
2,750 Test Cycles
Material Destroyed
3,500 Test Cycles
Pre-Test Weight
7,191.6 mg
Post-Test Weight
6,680.7 mg
Test End Loss Of Mass
Point Of Destruction
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 5
Strong Oxidants___________________ 5
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 3
Fungus ASTM G-21_________________ 2
Halogen Free____________________ Yes
RoHS___________________________ Yes
Minimum Continuous
-49°F (-45°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ NA
ASTM D-204
Recommended Cutting________ Scissor
Colors___________________________ 1
Wall Thickness__________________ .045”
Specific Gravity ASTM D-792_____ 1.14
Moisture Absorption_____________ 2.7
% ASTM D-570
Hard Vacuum Data __________________
ASTM E-595 at 10-5 torr
TML__________________________1.10
CVCM_________________________ .01
WVR___________________________ .69
Outgassing___________________ High
Oxygen Index____________________ 22
ASTM D-2863
510.9 mg
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Maximum Continuous
Abrasion Resistance
很抱歉,暂时无法提供与“DFN1.59BK50”相匹配的价格&库存,您可以联系我们找货
