DFN1.75BK50
DFN1.75BK50
    TECHFLEX
    DURA-FLEX 1.75" BLACK 50'
DFN1.75BK50 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups R  esists Snagging P  revents Damage From UV, Gasoline, Engine Chemicals And Salt R  esists Cut, Abrasion And Penetration F  lexible & Economical General Purpose Protection D  eflects High Pressure Hose Ruptures C  ustom Lengths Available Nominal Size Part # Wall Thickness Maxi Coil Bulk Spool Shop Spool Available Colors Lbs/ 100’ 0.71” 0.83” 0.92” 1.00” 1.13” 1.25” 1.34” 1.59” 1.75” 2.07” 2.38” 2.54” 2.86” 3.34” 3.66” DFN0.71BK DFN0.83BK DFN0.92BK DFN1.00BK DFN1.13BK DFN1.25BK DFN1.34BK DFN1.59BK DFN1.75BK DFN2.07BK DFN2.38BK DFN2.54BK DFN2.86BK DFN3.34BK DFN3.66BK .045” .045” .045” .045” .045” .045” .045” .045” .045” .045” .045” .045” .045” .045” .045” 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 300’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 25’ 25’ Black Black Black Black Black Black Black Black Black Black Black Black Black Black Black 2.57 2.58 3.22 3.66 4.18 4.49 4.84 5.37 6.13 7.26 8.28 8.98 9.89 11.59 12.25 Industrial Hose And Cable Protection For Harsh Environments The tightly woven nylon makes DF the perfect solution for hose & cable protection. The .045 inch wall thickness will protect cables, hoses and ropes from weather, sunlight and abrasion damage. Cut Cleanly Scissors Material Nylon Colors Available: Black (BK) When installed over uncoated cable or chains, DF will prevent scraping, chafing and contact damage to painted or other fragile surfaces. DF is resistant to chemicals, UV damage and rot, and is suitable for continuous outdoor use under all weather conditions. The flexible sleeving cuts with a scissor and the tight construction slides easily over any application. Grade DFN Wall Thickness .045” This is a non-expandable product. Be sure to match your application diameter accurately. Drawing Number TF001DF-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 ISO 6945 MSHA HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION 410°F (210°C) Mil-I-23053 Very High 248°F (120°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 70% Visible Wear And Some Pulling Of Fibers 500 Test Cycles Further Wear And Some Pulling At Seam 550 Test Cycles Material Wearing Through At Seam 2,750 Test Cycles Material Destroyed 3,500 Test Cycles Pre-Test Weight 7,191.6 mg Post-Test Weight 6,680.7 mg Test End Loss Of Mass Point Of Destruction CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 5 Strong Oxidants___________________ 5 Esters/Ketones____________________ 1 UV Light_________________________ 2 Petroleum________________________ 3 Fungus ASTM G-21_________________ 2 Halogen Free____________________ Yes RoHS___________________________ Yes Minimum Continuous -49°F (-45°C) PHYSICAL PROPERTIES Monofilament Diameter_________ NA ASTM D-204 Recommended Cutting________ Scissor Colors___________________________ 1 Wall Thickness__________________ .045” Specific Gravity ASTM D-792_____ 1.14 Moisture Absorption_____________ 2.7 % ASTM D-570 Hard Vacuum Data __________________ ASTM E-595 at 10-5 torr TML__________________________1.10 CVCM_________________________ .01 WVR___________________________ .69 Outgassing___________________ High Oxygen Index____________________ 22 ASTM D-2863 510.9 mg © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Maximum Continuous Abrasion Resistance
DFN1.75BK50 价格&库存
很抱歉,暂时无法提供与“DFN1.75BK50”相匹配的价格&库存,您可以联系我们找货
