AGA0.44YL50
AGA0.44YL50
    TECHFLEX
    SLEEVING0.438"IDFBRGLASS50'
AGA0.44YL50 数据手册
ADVANCED ENGINEERING ELECTRICAL INSULATION Technical Data Sheet Technical Data Sheet Rated to 155°C Class F Acrylic Resin Coated Fiberglass Sleeving Grade A & C UL Recognized ACRYLIC FLEX GLASS (AG) sleeving is a heat-treated, tightly braided fiberglass File# E329693 Grade A (7,000 V) Grade C (2,500 V) Cut and Abrasion Resistant sleeving coated with a dielectric acrylic resin. This durable sleeving will withstand mechanical stress and holds it’s dielectric strength on all bends. Acrylic Flex Glass is used in applications such as relays, radio circuits, transformers, and lead/crossover protection on motors. Highly resistant to acids and solvents, and will withstand tough assembly handling. Sleeving is recommended for thermal requirements from 105°C (221°F) to 155°C (311°F) ranges. Excellent Low Temp. Flexibility -13°F Resists Acids and Most Organic Solvents Colors Available: 4= YL, NT, BK, & RD. Acrylic Resin Coated Flex Glass sleeving has superior mechanical and electrical properties, providing its rated dielectric strength during and after the most severe handling in your application. Cut Cleanly Scissors Material Acrylic Coated Fiberglass Grade A&C Colors Available: Wall Thickness .014” - .040” Yellow (YL), Natural (NT), Black (BK) and Red (RD). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 ELECTRICAL ADVANCEDINSULATION ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups Diameter Part# Grade Wall Thickness (Grade A) Part# Grade Wall Thickness (Grade C) Bulk Spool Shop Spool Available Colors 24 22 20 18 16 14 12 11 10 9 8 7 6 5 4 3 2 1 0 3/8” 7/16” 1/2” 5/8” 3/4” 7/8” 1” 0.022” 0.027” 0.034” 0.042” 0.053” 0.066” 0.085” 0.095” 0.106” 0.118” 0.133” 0.148” 0.166” 0.186” 0.208” 0.234” 0.263” 0.294” 0.330” 0.375” 0.438” 0.500” 0.625” 0.750” 0.875” 1.000” AGAG.24 AGAG.22 AGAG.20 AGAG.18 AGAG.16 AGAG.14 AGAG.12 AGAG.11 AGAG.10 AGAG.09 AGAG.08 AGAG.07 AGAG.06 AGAG.05 AGAG.04 AGAG.03 AGAG.02 AGAG.01 AGAG.00 AGA0.38 AGA0.44 AGA0.50 AGA0.63 AGA0.75 AGA0.88 AGA1.00 A A A A A A A A A A A A A A A A A A A A A A A A A A .018” .018” .018” .018” .020” .020” .022” .022” .022” .024” .024” .024” .024” .028” .028” .028” .028” .028” .028” .034” .034” .034” .034” .040” .040” .040” AGCG.24 AGCG.22 AGCG.20 AGCG.18 AGCG.16 AGCG.14 AGCG.12 AGCG.11 AGCG.10 AGCG.09 AGCG.08 AGCG.07 AGCG.06 AGCG.05 AGCG.04 AGCG.03 AGCG.02 AGCG.01 AGCG.00 AGC0.38 AGC0.44 AGC0.50 AGC0.63 AGC0.75 AGC0.88 AGC1.00 C C C C C C C C C C C C C C C C C C C C C C C C C C .014” .014” .014” .014” .016” .016” .017” .017” .017” .019” .019” .019” .019” .023” .023” .023” .023” .023” .023” .030” .030” .030” .030” .038” .038” .038” 500’ 500’ 500’ 500’ 500’ 500’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD YL,NT,BK,RD RATE OF BURNING Conforms with requirements of NEMA TF-1, MIL-I-003190/3, and ASTM D372. CHEMICAL RESISTANCE Resistant to oils, acids, alkalies and most organic solvents. After more than 168 hours in the most commonly used aromatics, xylene and toluene, the dried sleeving substantially regains its original properties. LOW TEMPERATURE Bends without cracking at -25°C/-13°F. © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06-21 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Nominal Size
AGA0.44YL50 价格&库存
很抱歉,暂时无法提供与“AGA0.44YL50”相匹配的价格&库存,您可以联系我们找货
