166-90191
    HELLERMAN(海尔曼太通)
    HOSE0.66"IDPOLY100'BLACK
166-90191 数据手册
166-90191 Article Number: 166-90191 Description: HelaGuard Non-Metallic Conduit, Std. Weight, 0.50" Dia, Nylon PA6, Black, 100 ft/reel Base Data Local Order Number 166-90191 Type HG-SW0500 Color Black (BK) Features and benefits ‡Material is easy to use and cut; reduces installation time and labor costs. ‡Flexible, abrasion resistant and durable for a variety of applications. ‡Good impact strength; recovers quickly if crushed. ‡UV resistant; suitable for use in outdoor applications. ‡Offered in fine or course corrugated pitch. Quantity Per reel Product Description A standard weight corrugated conduit made of PA6 nylon that offers flexible abrasion protection for wire and cable bundles. Easy to cut and use, the material is highly resistant to solvents and oils. Combine with HelaGuard non-metallic fittings for IP66 rating or greater protection against water, wind and dirt. Technical Description Manufacturer Part No. FPAS21C Short Description HelaGuard Non-Metallic Conduit, Std. Weight, 0.50" Dia, Nylon PA6, Black, 100 ft/reel Length L (Imperial) 100.0ft Length L (Metric) 30.5m Inner Diameter D (Imperial) 0.63" Inner Diameter D (metric) 16.0mm Euro (NW) Size 17mm Pitch Type C (Coarse) Trade Size 1/2 " Outside Diameter D (imperial) 0.84" Outside Diameter D (metric) 21.2mm Nominal Diameter (Imperial) 1/2" Nominal Diameter (Metric) 21mm Inside Bend Radius (Imperial) 1.78" Product Dimensions generated on: 5/10/2017 166-90191 Product Dimensions Inside Bend Radius (Metric) 45mm Material Polyamide 6 (PA6) Material Shortcut PA6 Flammability UL 94 V2 Halogenfree Yes Operating Temperature -40°F to +248°F (-40°C to +120°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 100ft Package Quantity (Metric) 30.5m Customs Number(Schedule B) 3926909987 Weight (imperial) 0.047lbs Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90191
1. 物料型号:166-90191,型号为HG-SW0500。 2. 器件简介:HelaGuard非金属电缆保护管,标准重量,直径0.50英寸,由尼龙PA6制成,黑色,每卷100英尺。 3. 引脚分配:文档中未提及引脚分配,因为这是一个电缆保护管,不是电子元件。 4. 参数特性: - 颜色:黑色(BK) - 特点和优势:材料易于使用和切割,减少安装时间和人工成本。具有柔韧性、耐磨损和耐用性,适用于多种应用场景。具有良好的抗冲击性,如果被压碎可以迅速恢复。抗紫外线,适合户外使用。提供细波纹或粗波纹。 - 制造商部件编号:FPAS21C - 材料:聚酰胺6(PA6) - 材料缩写:PA6 - 可燃性:UL94V2 - 无卤素:是 - 工作温度:-40°F至+248°F(-40°C至+120°C) - 符合RoHS标准:是 - UL认可(美国和加拿大):是 5. 功能详解:标准重量波纹管,由PA尼龙制成,为电线和电缆束提供灵活的耐磨保护。材料易于切割和使用,高度抵抗溶剂和油脂。与HelaGuard非金属配件结合使用,可达到IP66等级或更高级别的防水、防风和防尘保护。 6. 应用信息:文档中未明确提及应用信息,但根据特点和优势,可以推断适用于需要耐磨、耐冲击和抗紫外线的电线和电缆保护。 7. 封装信息: - 卷长:100英尺(30.5米) - 内径:0.63英寸(16.0毫米) - 外径:0.84英寸(21.2毫米) - 贸易尺寸:1/2英寸 - 包装数量:每卷100英尺(30.5米) - 海关编号:3926909987 - 重量:0.047磅
166-90191 价格&库存
很抱歉,暂时无法提供与“166-90191”相匹配的价格&库存,您可以联系我们找货
