166-90220
    HELLERMAN(海尔曼太通)
    HOSE0.48"IDPVC100'BLACK
166-90220 数据手册
166-90220 Article Number: 166-90220 Description: HelaGuard SR PVC Tubing, Smooth Bore, Spiral Cover, Std Wt, 0.38" Dia, Bk, 100 ft/Std. Reel Base Data Local Order Number 166-90220 Type PSR0380 Color Black (BK) Features and benefits ‡Spiral reinforced construction provides protection from crushing yet remains extremely flexible. ‡Lightweight, easy-to-use material reduces installation time and labor costs. ‡Material stands up to vibration and limited torsional movement without creation of stress points or cracks. ‡Smooth inside bore protects wires and eases insertion of wire bundles. ‡UV resistant; suitable for use in outdoor applications. Quantity Per reel Product Description A lightweight tubing with a smooth inside bore, made of a spiral reinforced PVC material that provides high flexibility. This tubing is well-suited for protecting wire and cable bundles in extremely tight spaces. UV resistant. Use with HelaGuard NonMetallic Compression Fittings to create an enclosed system. Short Description HelaGuard SR PVC Tubing, Smooth Bore, Spiral Cover, Std Wt, 0.38" Dia, Bk, 100 ft/Std. Reel Length L (Imperial) 100.0ft Length L (Metric) 30.5m Inner Diameter D (Imperial) 0.48" Inner Diameter D (metric) 12mm Trade Size 3/8 " Outside Diameter D (imperial) 0.65" Outside Diameter D (metric) 16.5mm Nominal Diameter (Imperial) 3/8" Nominal Diameter (Metric) 16mm Inside Bend Radius (Imperial) 0.99" Inside Bend Radius (Metric) 25mm Product Dimensions generated on: 5/10/2017 166-90220 Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Flammability self-extinguishing according to EN IEC 61386 Halogenfree No Operating Temperature -4°F to +158°F (-20°C to +70°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 100ft Package Quantity (Metric) 30.5m Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90220 价格&库存
很抱歉,暂时无法提供与“166-90220”相匹配的价格&库存,您可以联系我们找货
    • 1+1164.21369
    库存:4
