166-90201
    HELLERMAN(海尔曼太通)
    HOSE1.87"IDPOLY50'BLACK
166-90201 数据手册
166-90201 Article Number: 166-90201 Description: HelaGuard Non-Metallic Conduit, Light Weight, 1.50" Dia, PA6, Black, 50 ft/Std. Reel Base Data Local Order Number 166-90201 Type HG-LW1500 Color Black (BK) Features and benefits ‡Lightweight and highly flexible for use in tight bend and fit applications. ‡Easy to use and cut; reduces installation time and labor costs. ‡Good abrasion resistance and impact strength; recovers quickly if crushed. ‡Offered in fine or course corrugated pitch. Quantity Per reel Product Description Lightweight nylon corrugated conduit provides high flexibility and good mechanical protection of wire and cable bundles, especially useful in smaller bend radius tight-fit applications. PA6 material offers high resistance to oils and solvents, along with good abrasion protection. Combine with HelaGuard non-metallic fittings for IP66 rating or greater protection against water, wind and dirt. Short Description HelaGuard Non-Metallic Conduit, Light Weight, 1.50" Dia, PA6, Black, 50 ft/Std. Reel Length L (Imperial) 50.0ft Length L (Metric) 15.2m Inner Diameter D (Imperial) 1.87" Inner Diameter D (metric) 47.2mm Euro (NW) Size 48mm Pitch Type C (Coarse) Trade Size 1-1/2 " Outside Diameter D (imperial) 2.15" Outside Diameter D (metric) 54.5mm Nominal Diameter (Imperial) 1-1/2" Nominal Diameter (Metric) 54mm Inside Bend Radius (Imperial) 3.15" Inside Bend Radius (Metric) 80mm Product Dimensions generated on: 5/10/2017 166-90201 Material and Specifications Material Polyamide 6 (PA6) Material Shortcut PA6 Flammability self-extinguishing according to EN IEC 61386 Halogenfree Yes Operating Temperature -40°F to +248°F (-40°C to +120°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 50ft Package Quantity (Metric) 15.2m Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90201 价格&库存
很抱歉,暂时无法提供与“166-90201”相匹配的价格&库存,您可以联系我们找货
