ADVANCED ENGINEERING
ELECTRICAL INSULATION
Technical Data Sheet
Rated to 200°C
Class H
FR Silicone Coated Fiberglass
Grade A, B, & C
UL Recognized
File# E329694
FLAME RETARDANT SILICONE FLEX GLASS (SF) sleeving is an extremely
flexible braided fiberglass sleeve coated with a flame retardant elastometric silicone rubber sheath.
Grade A (8,000 V)
Grade B (4,000 V)
Grade C (2,500 V)
NEMA TF-1 - TYPE 6
MIL-I-003190/6
The unique self-fitting construction allows SF sleeving to expand slightly for easy
installation, and provides a snug fit for minimum movement and reduced internal
abrasion.
SF sleeving is rated to 392°F. (Class H), is abrasion resistant, and maintains it’s flexibility in low temperature environments. It is available in a very wide range of sizes,
and is ideal for use in appliance assemblies, wire harnesses, transformer leads,
power supplies, motor coil and heater leads.
ASTM D372
Colors Available:
3= BK, WH & RD
Cut Cleanly
Scissors
Material
Grade
A, B, & C
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
FR Silicone Flex Glass is available in 3 colors:
Black (BK), White (WH) and Red (RD).
很抱歉,暂时无法提供与“SFAG.24BK”相匹配的价格&库存,您可以联系我们找货
