166-90195
Article Number:
166-90195
Description:
HelaGuard Non-Metallic Conduit, Std. Weight, 1.50" Dia,
Nylon PA6, Black, 50 ft/std reel
Base Data
Local Order Number
166-90195
Type
HG-SW1500
Color
Black (BK)
Features and benefits
Material is easy to use and cut; reduces installation time and labor costs.
Flexible, abrasion resistant and durable for a variety of applications.
Good impact strength; recovers quickly if crushed.
UV resistant; suitable for use in outdoor applications.
Offered in fine or course corrugated pitch.
Quantity Per
reel
Product Description
A standard weight corrugated conduit made of PA6 nylon that offers flexible
abrasion protection for wire and cable bundles. Easy to cut and use, the material is
highly resistant to solvents and oils. Combine with HelaGuard non-metallic fittings
for IP66 rating or greater protection against water, wind and dirt.
Short Description
HelaGuard Non-Metallic Conduit, Std. Weight, 1.50" Dia, Nylon PA6, Black, 50 ft/std
reel
Length L (Imperial)
50.0ft
Length L (Metric)
15.2m
Inner Diameter D (Imperial)
1.86"
Inner Diameter D (metric)
47.2mm
Euro (NW) Size
48mm
Pitch Type
C (Coarse)
Trade Size
1-1/2 "
Outside Diameter D (imperial)
2.15"
Outside Diameter D (metric)
54.5mm
Nominal Diameter (Imperial)
1-1/2"
Nominal Diameter (Metric)
54mm
Inside Bend Radius (Imperial)
3.15"
Inside Bend Radius (Metric)
80mm
Product
Dimensions
generated on:
5/10/2017
166-90195
Material and
Specifications
Material
Polyamide 6 (PA6)
Material Shortcut
PA6
Flammability
UL 94 V2
Halogenfree
Yes
Operating Temperature
-40°F to +248°F (-40°C to +120°C)
ROHS Compliant
Yes
UL Listed (US and Canada)
Yes
UL Listed (US)
Yes
Package Quantity (Imperial)
50ft
Package Quantity (Metric)
15.2m
Customs Number(Schedule B)
3926909987
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90195”相匹配的价格&库存,您可以联系我们找货
