166-90248
    HELLERMAN(海尔曼太通)
    TUBING0.63"IDPVC100'BLACK
166-90248 数据手册
166-90248 Article Number: 166-90248 Description: HelaGuard SR PVC Tubing, Smooth Bore, Smooth Cover, Std Wt, 0.50" Dia, Bk, 100 ft/Std. Reel Base Data Local Order Number 166-90248 Type LPC0500 Color Black (BK) Features and benefits ‡Spiral reinforced construction provides protection from crushing yet remains extremely flexible. ‡Lightweight, easy-to-use material reduces installation time and labor costs. ‡Material stands up to vibration and limited torsional movement without creation of stress points or cracks. ‡Smooth inside bore protects wires and eases insertion of wire bundles. ‡UV resistant; suitable for use in outdoor applications. ‡Outer surface wipes clean in wash-down environments. Quantity Per reel Product Description A lightweight, smooth tubing made of a spiral reinforced PVC material that provides high flexibility; well-suited for protecting wire and cable bundles in extremely tight spaces. UV resistant. Use with HelaGuard Metallic or Non Metallic Compression (PSR) Fittings for IP67 rating. Short Description HelaGuard SR PVC Tubing, Smooth Bore, Smooth Cover, Std Wt, 0.50" Dia, Bk, 100 ft/Std. Reel Length L (Imperial) 100.0ft Length L (Metric) 30.5m Inner Diameter D (Imperial) 0.63" Inner Diameter D (metric) 16mm Trade Size 1/2 " Outside Diameter D (imperial) 0.83" Outside Diameter D (metric) 21.1mm Nominal Diameter (Imperial) 1/2" Nominal Diameter (Metric) 20mm Inside Bend Radius (Imperial) 2.76" Inside Bend Radius (Metric) 70mm Product Dimensions generated on: 5/10/2017 166-90248 Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Flammability self-extinguishing according to EN IEC 61386-1 Halogenfree No Operating Temperature +23°F to +158°F (-5°C to +70°C) ROHS Compliant Yes Package Quantity (Imperial) 100ft Package Quantity (Metric) 30.5m Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90248 价格&库存
很抱歉,暂时无法提供与“166-90248”相匹配的价格&库存,您可以联系我们找货
