166-90222
Article Number:
166-90222
Description:
HelaGuard SR PVC Tubing, Smooth Bore, Spiral Cover,
Std Wt, 0.75" Dia, Bk, 100 ft/Std. Reel
Base Data
Local Order Number
166-90222
Type
PSR0750
Color
Black (BK)
Features and benefits
Spiral reinforced construction provides protection from crushing yet remains
extremely flexible.
Lightweight, easy-to-use material reduces installation time and labor costs.
Material stands up to vibration and limited torsional movement without creation of
stress points or cracks.
Smooth inside bore protects wires and eases insertion of wire bundles.
UV resistant; suitable for use in outdoor applications.
Quantity Per
reel
Product Description
A lightweight tubing with a smooth inside bore, made of a spiral reinforced PVC
material that provides high flexibility. This tubing is well-suited for protecting wire and
cable bundles in extremely tight spaces. UV resistant. Use with HelaGuard NonMetallic Compression Fittings to create an enclosed system.
Short Description
HelaGuard SR PVC Tubing, Smooth Bore, Spiral Cover, Std Wt, 0.75" Dia, Bk, 100
ft/Std. Reel
Length L (Imperial)
100.0ft
Length L (Metric)
30.5m
Inner Diameter D (Imperial)
0.87"
Inner Diameter D (metric)
22mm
Trade Size
3/4 "
Outside Diameter D (imperial)
1.09"
Outside Diameter D (metric)
27.5mm
Nominal Diameter (Imperial)
3/4"
Nominal Diameter (Metric)
25mm
Inside Bend Radius (Imperial)
1.78"
Inside Bend Radius (Metric)
45mm
Product
Dimensions
generated on:
5/10/2017
166-90222
Material and
Specifications
Material
Polyvinylchloride (PVC)
Material Shortcut
PVC
Flammability
self-extinguishing according to EN IEC 61386
Halogenfree
No
Operating Temperature
-4°F to +158°F (-20°C to +70°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
100ft
Package Quantity (Metric)
30.5m
Customs Number(Schedule B)
3926909987
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90222”相匹配的价格&库存,您可以联系我们找货
