166-90211
Article Number:
166-90211
Description:
HelaGuard Non-Metallic Conduit, Std. Weight, 1.00" Dia,
Nylon PA12, Black, 50 ft/Std. Reel
Base Data
Local Order Number
166-90211
Type
HG-HI1000
Color
Black (BK)
Features and benefits
Very high impact strength; recovers completely if crushed and provides excellent
fatigue life.
Highly UV resistant; suitable for use in outdoor applications.
Offered in fine or course corrugated pitch.
Offered with or without slit; slit options offer easy access during installation and
maintenance.
Quantity Per
reel
Product Description
A standard weight corrugated conduit made of PA12 nylon that offers superior
impact resistance, making it ideal for protecting wire and cable bundles in conditions
with continual movement or bending. This material is highly resistant to UV light,
solvents and oils. Combine with HelaGuard Non-Metallic Fittings to achieve IP66 or
greater protection against water, wind and dirt.
Short Description
HelaGuard Non-Metallic Conduit, Std. Weight, 1.00" Dia, Nylon PA12, Black, 50
ft/Std. Reel
Length L (Imperial)
50.0ft
Length L (Metric)
15.2m
Inner Diameter D (Imperial)
1.11"
Inner Diameter D (metric)
28.1mm
Euro (NW) Size
29mm
Pitch Type
C (Coarse)
Trade Size
1"
Outside Diameter D (imperial)
1.36"
Outside Diameter D (metric)
34.5mm
Nominal Diameter (Imperial)
1"
Nominal Diameter (Metric)
34mm
Inside Bend Radius (Imperial)
2.17"
Product
Dimensions
generated on:
5/10/2017
166-90211
Product
Dimensions
Inside Bend Radius (Metric)
55mm
Material
Polyamide 12 (PA12)
Material Shortcut
PA12
Flammability
self-extinguishing according to EN IEC 61386
Halogenfree
Yes
Operating Temperature
-58°F to +230°F (-50°C to +110°C)
ROHS Compliant
Yes
UL Recognized (US and Canada)
Yes
UL Recognized (US)
Yes
Package Quantity (Imperial)
50ft
Package Quantity (Metric)
15.2m
Customs Number(Schedule B)
3926909987
Material and
Specifications
Logistic and
Packaging
generated on:
5/10/2017
很抱歉,暂时无法提供与“166-90211”相匹配的价格&库存,您可以联系我们找货
