166-90223
    HELLERMAN(海尔曼太通)
    HOSE1.11"IDPVC100'BLACK
166-90223 数据手册
166-90223 Article Number: 166-90223 Description: HelaGuard SR PVC Tubing, Smooth Bore, Spiral Cover, Std Wt, 1.00" Dia, Bk, 100 ft/Std. Reel Base Data Local Order Number 166-90223 Type PSR1000 Color Black (BK) Features and benefits ‡Spiral reinforced construction provides protection from crushing yet remains extremely flexible. ‡Lightweight, easy-to-use material reduces installation time and labor costs. ‡Material stands up to vibration and limited torsional movement without creation of stress points or cracks. ‡Smooth inside bore protects wires and eases insertion of wire bundles. ‡UV resistant; suitable for use in outdoor applications. Quantity Per reel Product Description A lightweight tubing with a smooth inside bore, made of a spiral reinforced PVC material that provides high flexibility. This tubing is well-suited for protecting wire and cable bundles in extremely tight spaces. UV resistant. Use with HelaGuard NonMetallic Compression Fittings to create an enclosed system. Short Description HelaGuard SR PVC Tubing, Smooth Bore, Spiral Cover, Std Wt, 1.00" Dia, Bk, 100 ft/Std. Reel Length L (Imperial) 100.0ft Length L (Metric) 30.5m Inner Diameter D (Imperial) 1.11" Inner Diameter D (metric) 28mm Trade Size 1" Outside Diameter D (imperial) 1.32" Outside Diameter D (metric) 33.5mm Nominal Diameter (Imperial) 1" Nominal Diameter (Metric) 32mm Inside Bend Radius (Imperial) 2.36" Inside Bend Radius (Metric) 60mm Product Dimensions generated on: 5/10/2017 166-90223 Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Flammability self-extinguishing according to EN IEC 61386 Halogenfree No Operating Temperature -4°F to +158°F (-20°C to +70°C) ROHS Compliant Yes UL Recognized (US) Yes UL Recognized (US and Canada) Yes Package Quantity (Imperial) 100ft Package Quantity (Metric) 30.5m Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/10/2017
166-90223
1. 物料型号:166-90223,属于PSR1000型号。 2. 器件简介:这是一种螺旋加固的PVC管,内壁光滑,具有高柔韧性,适用于在极窄空间内保护电线和电缆束。它还具有UV抗性,适合户外使用。 3. 引脚分配:文档中未提及引脚分配,因为这不是电子元件,而是一种保护电线和电缆的管材。 4. 参数特性: - 颜色:黑色(BK)。 - 材质:聚氯乙烯(PVC)。 - 阻燃性:根据EN IEC 61386标准,具有自熄性。 - 无卤素:否。 - 工作温度:-4°F至+158°F(-20°C至+70°C)。 - 符合RoHS标准:是。 - 美国UL认证:是。 - 美国和加拿大UL认证:是。 5. 功能详解:螺旋加固结构提供防压保护,同时保持极高的柔韧性。材料轻便,易于使用,减少安装时间和人工成本。材料能够承受振动和有限的扭转运动,不会产生应力点或裂纹。内壁光滑,保护电线并便于插入电线束。 6. 应用信息:推荐与HelaGuard非金属压缩配件一起使用,以创建封闭系统。 7. 封装信息: - 产品尺寸:100英尺(30.5米)长,内径1.11英寸(28毫米),外径1.32英寸(33.5毫米)。 - 贸易尺寸:1。 - 内弯曲半径:2.36英寸(60毫米)。 - 包装数量:100英尺(30.5米)。
166-90223 价格&库存
很抱歉,暂时无法提供与“166-90223”相匹配的价格&库存,您可以联系我们找货
