F360.75BKBB
F360.75BKBB
    TECHFLEX
    SLEEVING0.75"IDPET500'BLACK
F360.75BKBB 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups E  asy, Cost And Labor Effective Installation S  oft And Quiet In High Vibration Uses C  ut And Abrasion Resistant C  hemically Inert H  alogen Free Nominal Size Part # Wall Thickness ±.005” Monofilament Diameter Bulk Box Box A Box B Available Colors Lbs/ 100’ 3/8” 1/2” 3/4” 1” 1 1/4” 1 3/8” 1 1/2” 2” F360.38BK F360.50BK F360.75BK F3601.00BK F3601.25BK F3601.38BK F3601.50BK F3602.00BK .028” .028” .028” .028” .028” .028” .040” .040” .010” .010” .010” .010” .010” .010” .015” .015” 1,500’ 1,200’ 500’ 400’ 250’ 200’ 150’ 100’ 150’ 150’ 100’ 100’ 75’ 75’ 75’ 50’ 75’ 75’ 50’ 50’ 25’ 25’ 25’ 25’ 1 1 1 1 1 1 1 1 0.83 1.14 1.53 1.67 2.26 2.48 3.90 5.37 360° of Complete Coverage of Flexible, Semi-Rigid Braided Conduit F360° is an innovative conduit designed to encase your wires with a flexible structure. F360’s circular shape is lightweight yet extremely strong. Utilizing our now famous F6 style triaxial braid technology, this new design will solve situations that need additional security and tamper resistance. The full 360° degree enclosure makes a sturdy wire duct while still remaining breathable and light. Feeding wires through F360° is easy due to the ridged design. The beautifully finished bundle will maintain it’s shape and add serious protection for a very long life. Cut Cleanly Hot Knife Material Polyethylene Terephthalate Grade F360 Monofilament Diameter .010” - .015” F360° braid is lightweight and quiet. It will bend to a tight radius without distorting , and it will not impair or affect the flexibility of harnesses. Drawing Number TF001F360-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 FAR-25 Colors Available: Black (BK) GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION High Rating______________________UL94VO Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 74% Some Scuffing Visible 500 Test Cycles Significant Wear Is Visible With Several Braid Filaments Broken 1,200 Test Cycles Material Destroyed 1,950 Test Cycles Pre-Test Weight 5,365.1 mg Post-Test Weight 4,850 mg Test End Loss Of Mass Point Of Destruction 515.1 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter____.010”-.015” ASTM D-204 Flammability Rating____________ UL94 Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness____________ .028”-.040” Tensile Strength (Yarn)___________6-10 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data ASTM E-595 TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 482°F (250°C)
F360.75BKBB 价格&库存
很抱歉,暂时无法提供与“F360.75BKBB”相匹配的价格&库存,您可以联系我们找货
