FIN0.38RD
FIN0.38RD
    TECHFLEX
    FIREFLEX FIBERGLASS 3/8" RED 100
FIN0.38RD 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups S  table to 500°F Nominal Size Part # Wall Thickness ±0.010” Bulk Spool Shop Spool J acketed With A Non-Permeable, Heavy Silicone Coating That Is Flexible Enough To Follow Tight Radius Curves 1/4” 3/8” 1/2” 5/8” 3/4” 7/8” 1” 1 1/4” 1 1/2” 1 3/4” 2” 2 1/4” 2 3/8” 2 1/2” 2 3/4” 2 7/8” 3” 3 1/2” 4” FIN0.25 FIN0.38 FIN0.50 FIN0.63 FIN0.75 FIN0.88 FIN1.00 FIN1.25 FIN1.50 FIN1.75 FIN2.00 FIN2.25 FIN2.38 FIN2.50 FIN2.75 FIN2.88 FIN3.00 FIN3.50 FIN4.00 .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” .072” 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 25’ 25’ 50’ 50’ 50’ 50’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ - C  ontains Radiant Heat To Prevent Damage To Nearby Components R  esists Gasoline And Engine Chemicals Cut And Abrasion Resistant Silicone Jacketed Fiberglass Resists Heat, Abrasion And Moisture Cut Cleanly Scissors Material FIN Silicone Jacketed Fiberglass Grade FIN Wall Thickness .072” Available Colors BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, RD, SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV Lbs/ 100’ 4.80 6.30 7.40 8.80 9.80 10.10 13.50 14.00 14.70 16.30 20.50 22.90 26.90 28.30 30.10 32.00 33.40 37.20 40.10 Colors Available: 3= BK, RD, SV Silicone jacketed fiberglass sleeving is the choice of professionals in racing and other industries where protection from constant temperatures approaching 500° F is mandatory. Engineered to contain radiant exhaust and coolant heat within pipes and hoses and to protect expensive performance equipment and operators from thermal damage. FireFlex is completely non-conductive, will not melt, delaminate, become brittle or support combustion under normal conditions, and provides a professional level solution to thermal protection needs in any application. Drawing Number TF001FIN-WD Fuel lines in race cars are especially vulnerable to high engine temperatures. FireFlex can help maintain proper fuel temperature. Colors Available: Black (BK), Red (RD) and Silver (SV). www.techflex.com 800.323.5140 • 973.300.9242 • fax: 973.300.9409 104 Demarest Road • Sparta, NJ 07871 HALOGEN FREE EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION Extreme Abrasion Test Machine Rating_______________ Non Flammable ___________________Non Combustible Maximum Continuous Mil-I-23053 500°F (260°C) Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 71°F Humidity 61% Small Hole In Coating 400 Test Cycles Several Small Holes Worn Through Coating 1,200 Test Cycles Coating Worn Through -No Wear On Fiberglass 4,800 Test Cycles Fiberglass Begins To Show Moderate Wear 6,500 Test Cycles Material Destroyed 8,400 Test Cycles Pre-Test Weight 22,961.3 mg Post-Test Weight 20,942.2 mg Test End Loss Of Mass Point Of Destruction 2,019.1 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC______________________________ Minimum Continuous -65°F (-54°C) PHYSICAL PROPERTIES Monofilament Diameter_________ NA ASTM D-204 Flammability Rating___ Non Flammable Recommended Cutting________ Scissor Colors___________________________3 Wall Thickness__________________.072” Tensile Strength (Yarn)_______________ ASTM D-2256 Lbs Specific Gravity ASTM D-792________ NA © 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 01-08 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY 2,048°F (1,120°C)
FIN0.38RD 价格&库存
很抱歉,暂时无法提供与“FIN0.38RD”相匹配的价格&库存,您可以联系我们找货
