ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
E
asy, Cost And Labor
Effective Installation
S
oft And Quiet In High
Vibration Uses
C
ut And Abrasion Resistant
C
hemically Inert
H
alogen Free
Nominal
Size
Part
Wall
Thickness
±.005”
Monofilament
Diameter
Bulk
Box
Box
A
Box
B
Available
Colors
Lbs/
100’
3/8”
1/2”
3/4”
1”
1 1/4”
1 3/8”
1 1/2”
2”
F360.38BK
F360.50BK
F360.75BK
F3601.00BK
F3601.25BK
F3601.38BK
F3601.50BK
F3602.00BK
.028”
.028”
.028”
.028”
.028”
.028”
.040”
.040”
.010”
.010”
.010”
.010”
.010”
.010”
.015”
.015”
1,500’
1,200’
500’
400’
250’
200’
150’
100’
150’
150’
100’
100’
75’
75’
75’
50’
75’
75’
50’
50’
25’
25’
25’
25’
1
1
1
1
1
1
1
1
0.83
1.14
1.53
1.67
2.26
2.48
3.90
5.37
360° of Complete Coverage of Flexible,
Semi-Rigid Braided Conduit
F360° is an innovative conduit designed to encase your
wires with a flexible structure. F360’s circular shape is
lightweight yet extremely strong. Utilizing our now
famous F6 style triaxial braid technology, this new
design will solve situations that need additional security
and tamper resistance. The full 360° degree enclosure
makes a sturdy wire duct while still remaining breathable and light. Feeding wires through F360° is easy due
to the ridged design. The beautifully finished bundle
will maintain it’s shape and add serious protection for a
very long life.
Cut Cleanly
Hot Knife
Material
Polyethylene Terephthalate
Grade
F360
Monofilament Diameter
.010” - .015”
F360° braid is lightweight and quiet.
It will bend to a tight radius without
distorting , and it will not impair or
affect the flexibility of harnesses.
Drawing Number
TF001F360-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
FAR-25
Colors Available:
Black (BK)
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
High
Rating______________________UL94VO
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
74%
Some Scuffing Visible
500 Test Cycles
Significant Wear Is Visible
With Several Braid
Filaments Broken
1,200 Test Cycles
Material Destroyed
1,950 Test Cycles
Pre-Test Weight
5,365.1 mg
Post-Test Weight
4,850 mg
Test End Loss Of Mass
Point Of Destruction
515.1 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter____.010”-.015”
ASTM D-204
Flammability Rating____________ UL94
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness____________ .028”-.040”
Tensile Strength (Yarn)___________6-10
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data ASTM E-595
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
很抱歉,暂时无法提供与“F3601.00BKBB”相匹配的价格&库存,您可以联系我们找货
