DTT500-5/8-025
DTT500-5/8-025
    DABURNELECTRONICS
    DAFLON WALL TUBING 5/8
DTT500-5/8-025 数据手册
#DTT500 DAFLON Thin Wall PTFE Tubing, MIL-I-22129, AMS 3655 TEL: 973-328-3200 Page 1 of 2 FAX: 973-328-3130 Home > Tubing > Non-Shrinkable Tubing > #DTT500 DAFLON Thin Wall PTFE Tubing, MIL-I22129, AMS 3655 #DTT500 DAFLON Thin Wall PTFE Tubing, MIL-I-22129, AMS 3655 Description: Daflon 500 tubing is extruded from PTFE resin and is unmatched by any other tubing for use in applications for hi-frequencies and hi-temperatures. Rated for continuous operation of 250°C, it retains its toughness and flexibility throughout. It has high resistance to fatigue and stress, with superior dielectric strength at high frequencies. It will not shrink back during soldering operation. Daflon tubing is flexible and non-flammable, it permits miniaturization of design and compactness and has the lowest coefficient of friction. In addition, it is inert to all fungus growth. It conforms to MIL-I-22129C Spec. AMS 3654, AMS 3655, ASTM-D-3295. This series is RoHS compliant. Nom. I.D. Wall Thickness Standard Spool DAFLON Size or Coil (Note 1) Catalog No. IN. MM. IN. MM. DTT500-30 30 0.012 0.30 0.009 0.23 100', 500', 1000' DTT500-28 28 0.015 0.38 0.009 0.23 100', 500', 1000' DTT500-26 26 0.018 0.46 0.010 0.25 100', 500', 1000' DTT500-24 24 0.022 0.56 0.010 0.25 25', 50', 100', 500', 1000' DTT500-22 22 0.027 0.69 0.010 0.25 25', 50', 100', 500', 1000' DTT500-20 20 0.034 0.86 0.012 0.30 25', 50', 100', 500', 1000' DTT500-19 19 0.038 0.96 0.012 0.30 100', 1000' DTT500-18 18 0.042 1.07 0.012 0.30 25', 50', 100', 500', 1000' DTT500-17 17 0.047 1.19 0.012 0.30 100', 1000' DTT500-16 16 0.053 1.35 0.012 0.30 25', 50', 100', 500', 1000' DTT500-15 15 0.059 1.50 0.012 0.30 100', 1000' DTT500-14 14 0.066 1.68 0.012 0.30 25', 50', 100', 500' DTT500-13 13 0.076 1.93 0.012 0.30 100', 500' DTT500-12 12 0.085 2.16 0.012 0.30 25', 50', 100', 500' DTT500-11 11 0.095 2.41 0.012 0.30 100', 500' DTT500-10 10 0.106 2.69 0.012 0.30 25', 50', 100', 500' DTT500-9 9 0.118 3.00 0.015 0.38 100', 500' DTT500-8 8 0.133 3.38 0.015 0.38 25', 50', 100', 500', 1000'* DTT500-7 7 0.148 3.76 0.015 0.38 100, 500, 1000'* DTT500-6 6 0.166 4.22 0.015 0.38 25', 50', 100', 1000'* DTT500-5 5 0.186 4.72 0.015 0.38 100', 1000'* DTT500-4 4 0.208 5.28 0.015 0.38 50', 100', 1000'* DTT500-3 3 0.234 5.94 0.015 0.38 100', 1000'* DTT500-2 2 0.263 6.68 0.015 0.38 25', 50', 100', 1000'* DTT500-1 1 0.294 7.47 0.015 0.38 100', 1000'* DTT500-0 0 0.330 8.38 0.015 0.38 25', 50', 100', 1000'* DTT500-1/8 1/8" 0.125 3.18 0.015 0.38 50', 100' DTT500-1/4 1/4" 0.250 6.35 0.015 0.38 50', 100', 1000'* DTT500-5/16 5/16" 0.312 7.93 0.015 0.38 50', 100', 1000'* DTT500-3/8** 3/8" 0.390 9.91 0.015 0.38 50', 100' DTT500-7/16** 7/16" 0.453 11.51 0.018 0.46 50', 100' DTT500-1/2** 1/2" 0.515 13.08 0.018 0.46 25', 50', 100' DTT500-5/8** 5/8" 0.640 16.26 0.020 0.51 25', 50', 100' DTT500-3/4** 3/4" 0.765 19.43 0.025 0.64 25, 50, 100' * Random lengths in coils. ** Random Straight lengths. Stock Colors: Natural. Call for Red, Black, Yellow, Blue, Brown, Green, Orange, Gray, Violet, White. If no color is specified, Natural will be supplied. Nos. DTT500-3/8 thru 1" available from stock in Natural. Additional colors, sizes made to order. Note 1: Please call to order quantities less than 100'. Table of Properties for PTFE Tubing Test ASTM Method Result Tensile Strength, 73°F D638-52T 1500-300 Lb/Square Inch Elongation, 73°F D638-52T 100-200% Deformation Under Load-122°F 1200 Lb/SQ IN., 24hrs D621-51 4-8% 2000 Lb/SQ IN., 24hrs D621-51 25% Hardness Durometer D676-49T D50-D65 Heat Distortion Temp, 6 LB/SQ IN. D648B-45T 250° C http://www.daburn.com/dtt500daflonthinwallptfetubingmil-i-22129ams3655.aspx 5/16/2016 #DTT500 DAFLON Thin Wall PTFE Tubing, MIL-I-22129, AMS 3655 Dielectric Strength .080" Surface Arc-Resistance Volume Resistivity D149-44 D495-48T D257-52T 400-500 V/Mil SEC. Surface Resistivity, 100%RH D257-52T 3.6X106 MegOhms 2.00 Dielectric Constant, 60 to 108Cyc D150-54T D150-54T Power Factor, 60 to 108 Cycles Specific Gravity D792-50 Page 2 of 2 1015 Ohms-CM 0.0003 2.1-2.2 PTFE light wall tubing (DTT501 series) and standard wall tubing (DTT550 series) are available. © 2015 Daburn Electronics & Cable E-Commerce Web Site http://www.daburn.com/dtt500daflonthinwallptfetubingmil-i-22129ams3655.aspx 5/16/2016
DTT500-5/8-025 价格&库存
很抱歉,暂时无法提供与“DTT500-5/8-025”相匹配的价格&库存,您可以联系我们找货
