SFC1.00BK50
SFC1.00BK50
    TECHFLEX
    SLEEVING1"IDFBRGLASS50'BLK
SFC1.00BK50 数据手册
ADVANCED ENGINEERING ELECTRICAL INSULATION Technical Data Sheet Technical Data Sheet Rated to 200°C Class H FR Silicone Coated Fiberglass Grade A, B, & C UL Recognized File# E329694 FLAME RETARDANT SILICONE FLEX GLASS (SF) sleeving is an extremely flexible braided fiberglass sleeve coated with a flame retardant elastometric silicone rubber sheath. Grade A (8,000 V) Grade B (4,000 V) Grade C (2,500 V) NEMA TF-1 - TYPE 6 MIL-I-003190/6 The unique self-fitting construction allows SF sleeving to expand slightly for easy installation, and provides a snug fit for minimum movement and reduced internal abrasion. SF sleeving is rated to 392°F. (Class H), is abrasion resistant, and maintains it’s flexibility in low temperature environments. It is available in a very wide range of sizes, and is ideal for use in appliance assemblies, wire harnesses, transformer leads, power supplies, motor coil and heater leads. ASTM D372 Colors Available: 3= BK, WH & RD Cut Cleanly Scissors FR Silicone Flex Glass is available in 3 colors: Black (BK), White (WH) and Red (RD). Material Silicone Coated Fiberglass Grade A, B, & C www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 VW-1 ELECTRICAL ADVANCEDINSULATION ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups Diameter Part# Grade Available Colors Part# Grade Part# Grade Available Colors Bulk Spool Shop Spool 24 22 20 18 16 14 12 10 9 8 7 6 5 4 3 2 1 0 3/8” 7/16” 1/2” 5/8” 3/4” 7/8” 1” 1 1/4” 1 1/2” 0.022” 0.027” 0.034” 0.042” 0.053” 0.066” 0.085” 0.106” 0.118” 0.133” 0.148” 0.166” 0.186” 0.208” 0.234” 0.263” 0.294” 0.330” 0.375” 0.438” 0.500” 0.625” 0.750” 0.875” 1.000” 1.250” 1.500” SFAG.24 SFAG.22 SFAG.20 SFAG.18 SFAG.16 SFAG.14 SFAG.12 SFAG.10 SFAG.09 SFAG.08 SFAG.07 SFAG.06 SFAG.05 SFAG.04 SFAG.03 SFAG.02 SFAG.01 SFAG.00 SFA0.38 SFA0.44 SFA0.50 SFA0.63 SFA0.75 SFA0.88 SFA1.00 SFA1.25 SFA1.50 A A A A A A A A A A A A A A A A A A A A A A A A A A A BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD SFBG.24 SFBG.22 SFBG.20 SFBG.18 SFBG.16 SFBG.14 SFBG.12 SFBG.10 SFBG.09 SFBG.08 SFBG.07 SFBG.06 SFBG.05 SFBG.04 SFBG.03 SFBG.02 SFBG.01 SFBG.00 SFBG.38 SFBG.44 SFBG.50 SFBG.63 SFBG.75 SFBG.88 SFBG1.00 N/A N/A B B B B B B B B B B B B B B B B B B B B B B B B B SFCG.24 SFCG.22 SFCG.20 SFCG.18 SFCG.16 SFCG.14 SFCG.12 SFCG.10 SFCG.09 SFCG.08 SFCG.07 SFCG.06 SFCG.05 SFCG.04 SFCG.03 SFCG.02 SFCG.01 SFCG.00 SFC0.38 SFC0.44 SFC0.50 SFC0.63 SFC0.75 SFC0.88 SFC1.00 N/A N/A C C C C C C C C C C C C C C C C C C C C C C C C C N/A N/A BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD BK,WH,RD N/A N/A 500’ 500’ 500’ 500’ 500’ 500’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 250’ 250’ 250’ 250’ 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ N/A N/A CHEMICAL RESISTANCE Resistant to oils, acids, alkalies, organic solvents and aliphatic hydrocarbons. OPERATING TEMPERATURE RANGE -75°C/-103°F to 220°C/428°F © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06-21 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Nominal Size
SFC1.00BK50 价格&库存
很抱歉,暂时无法提供与“SFC1.00BK50”相匹配的价格&库存,您可以联系我们找货
