D200-3/4-100FT
D200-3/4-100FT
    DABURNELECTRONICS
D200-3/4-100FT 数据手册
#D200 DAFLEX Silicone Rubber Coated Fiberglass Sleeving MIL-I-3190/6 TEL: 973-328-3200 Page 1 of 2 FAX: 973-328-3130 Home > Tubing > Non-Shrinkable Tubing > #D200 DAFLEX Silicone Rubber Coated Fiberglass Sleeving MIL-I-3190/6 #D200 DAFLEX Silicone Rubber Coated Fiberglass Sleeving MIL-I3190/6 Description: Braided fiberglass sleeving with a uniform coating of silicone rubber. Cuts cleanly and will not fray. The tubing remains flexible from -55°C to +200°C. Can be "pushed-back" easily; has high cut through resistance, and is unaffected by corona, ozone, radiation, weathering and fungus, with excellent abrasion, chemical and moisture resistance, self-extinguishes flame. UL Rated: 600V. This series is RoHS compliant. MIL-I-3190 Inside Diameter (IN.) Stock Spool DAFLEX Size Size or Coil Cat. No. Min. Nom. Max. D200-24 24 01 0.02 0.022 0.027 100', 500', 1000' D200-22 22 02 0.025 0.027 0.032 100', 500', 1000' D200-20 20 03 0.032 0.034 0.039 100', 500', 1000' D200-18 18 04 0.040 0.042 0.049 100', 500', 1000' D200-16 16 06 0.051 0.053 0.061 100', 500', 1000' D200-15 15 07 0.057 0.059 0.067 100', 500', 1000' D200-14 14 08 0.064 0.066 0.074 100', 500' D200-13 13 09 0.072 0.076 0.082 100', 500' D200-12 12 10 0.081 0.085 0.091 100', 500' D200-11 11 11 0.091 0.095 0.101 100', 500' D200-10 10 12 0.102 0.106 0.112 100', 500' D200-9 9 13 0.114 0.118 0.124 100', 500' D200-8 8 14 0.129 0.133 0.141 100', 500' D200-7 7 15 0.144 0.148 0.158 100', 500' D200-6 6 16 0.162 0.166 0.178 100' D200-5 5 17 0.182 0.186 0.198 100' D200-4 4 18 0.204 0.208 0.224 100' D200-3 3 19 0.229 0.234 0.249 100' D200-2 2 20 0.258 0.263 0.278 100' D200-1 1 21 0.289 0.294 0.311 100' D200-0 0 22 0.325 0.330 0.347 100' D200-3/8 3/8" 23 0.375 0.387 0.399 100' D200-7/167/16" 24 0.438 0.450 0.462 100' D200-1/2 1/2" 25 0.500 0.512 0.524 100' D200-5/8 5/8" 26 0.625 0.640 0.655 100' D200-3/4 3/4" 27 0.750 0.768 0.786 100' D200-7/8 7/8" 28 0.875 0.893 0.911 100' D200-1" 1" 29 1.000 1.006 1.036 100' Stock Color: White. Additional colors and grades available to order. Specifications: NEMA Grade A, (7000V) Class "R", VS-1, ASTM-D372, UL Standard 1441, MIL-I3190/6 Grade A. © 2015 Daburn Electronics & Cable E-Commerce Web Site http://www.daburn.com/d200daflexsiliconerubbercoatedfiberglasssleeving.aspx 5/16/2016
D200-3/4-100FT 价格&库存
很抱歉,暂时无法提供与“D200-3/4-100FT”相匹配的价格&库存,您可以联系我们找货
