SGH0.38RD
SGH0.38RD
    TECHFLEX
    Red Fiberglass, Silicone Coated Braided Sleeving, Insulated 0.375" (9.52mm) 100' (30.48m)
SGH0.38RD 数据手册
ADVANCED ENGINEERING ELECTRICAL INSULATION Technical Data Sheet Technical Data Sheet Rated to 200°C Class H UL Recognized 15,000 V Cut and Abrasion Resistant Heavy Wall Silicone Coated Fiberglass Sleeving HEAVY WALL FLEX GLASS (SG) is engineered from a high quality braided fiberglass sleeve surrounded by a heavy silicone rubber coating. SG expands slightly for easy installation, and is tough and flexible enough for use in tight radius applications. The silicone coating will expand and flex without cracks or fractures, and the treated fiberglass minimizes end fray and dusting during assembly and use. Heavy Wall Flex Glass resists dielectric breakdown caused by operational stresses. Excellent Low Temp. Flexibility SG is highly abrasion resistant and remains flexible in low temperature applications. It is also resistant to common chemicals, inorganic acids, alkalis and alphatic hydrocarbons. Rated to 392°F. (Class H), Heavy Wall Silicone Flex Glass is in extensive use in dry-type transformer applications. Colors Available: Red (RD) Cut Cleanly Scissors Material Silicone Coated Fiberglass www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Heavy Wall Silicone Flex Glass is ideal for terminal insulation and protection in a wide range of operating environments up to 15,000 Volts. ELECTRICAL ADVANCEDINSULATION ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups Diameter Part# Grade Bulk Spool Shop Spool Available Colors 14 0.066” SGHG.14RD 15,000 V 500’ N/A Red (RD) 12 0.085” SGHG.12RD 15,000 V 250’ N/A Red (RD) 10 0.106” SGHG.10RD 15,000 V 250’ N/A Red (RD) 9 0.118” SGHG.09RD 15,000 V 250’ N/A Red (RD) 8 0.133” SGHG.08RD 15,000 V 250’ N/A Red (RD) 7 0.148” SGHG.07RD 15,000 V 250’ N/A Red (RD) 6 0.166” SGHG.06RD 15,000 V 250’ N/A Red (RD) 5 0.186” SGHG.05RD 15,000 V 250’ N/A Red (RD) 4 0.208” SGHG.04RD 15,000 V 250’ N/A Red (RD) 3 0.234” SGHG.03RD 15,000 V 250’ N/A Red (RD) 2 0.263” SGHG.02RD 15,000 V 250’ N/A Red (RD) 1 0.294” SGHG.01RD 15,000 V 250’ N/A Red (RD) 0 0.330” SGHG.00RD 15,000 V 100’ N/A Red (RD) 3/8” 0.375” SGH0.38RD 15,000 V 100’ N/A Red (RD) 7/16” 0.438” SGH0.44RD 15,000 V 100’ N/A Red (RD) 1/2” 0.500” SGH0.50RD 15,000 V 100’ N/A Red (RD) 5/8” 0.625” SGH0.63RD 15,000 V 100’ N/A Red (RD) 3/4” 0.750” SGH0.75RD 15,000 V 100’ N/A Red (RD) 7/8” 0.875” SGH0.88RD 15,000 V 50’ N/A Red (RD) 1” 1.000” SGH1.00RD 15,000 V 50’ N/A Red (RD) CHEMICAL RESISTANCE Resists inorganic acids, alkalis and aliphatic hydrocarbons. LOW TEMPERATURE Brittle point below -85°C/-121°F © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06-21 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Nominal Size
SGH0.38RD 价格&库存
很抱歉,暂时无法提供与“SGH0.38RD”相匹配的价格&库存,您可以联系我们找货
