FPB
FPB
    HELLERMAN(海尔曼太通)
FPB 数据手册
FPB Article Number: 251-10209 Grommet, Panel Thickness 0.051''-0.083'', PE, Natural, 82ft/pkg Download drawing Download spec sheet Base Data Local Order Number FPB Type G51PB Color Natural (NA) Features and Benefits • Can be cut to length with scissors, eliminating waste and keeping stock to a minimum. • Available in 9 sizes, for thicknesses from .016" to .512", insuring proper fit. Product Description HellermannTyton's Flexiform grommet is a unique, continuous wire protection product which fits easily in all shapes and sizes of holes without the aid of tools or adhesives. Flexiform grommet can be used on any type of material including wood, steel, aluminum, plexiglass, and glass. Short Description Grommet, Panel Thickness 0.051''-0.083'', PE, Natural, 82ft/pkg Product Dimensions Length L (Imperial) 82.0 ft Reel Length (imperial) 9.7 ft Variant Open Width W (Imperial) 0.181 " Width W (Metric) 4.6 mm Width W2 (Imperial) 0.094 " Width W2 (Metric) 2.4 mm Height H (Imperial) 0.169 " Height H (Metric) 4.3 mm Height H2 (Imperial) 0.106 " Height H2 (Metric) 2.7 mm Panel Thickness Max. (Imperial) 0.083 " Panel Thickness Max. (Metric) 2.10 mm Panel Thickness Min. (Imperial) 0.051 " Panel Thickness Min. (Metric) 1.30 mm Logistics and Packaging Quantity Per reel Package Quantity 82.0 ft Package Quantity (Metric) 25 m Carton Quantity 1 Reel Weight (Metric) 0.33 kg Material and Specifications Material Polyethylene (PE) Material Shortcut PE Flammability UL94 HB Halogenfree Yes Operating Temperature -22°F to +176°F (-30°C to +80°C) ROHS Compliant Yes © HellermannTyton 2015
很抱歉,暂时无法提供与“FPB”相匹配的价格&库存,您可以联系我们找货
