712A1000
712A1000
    GREENLEECOMMUNICATIONS(格林利)
712A1000 数据手册
BUSHING (1000 PC) 712A1000 1,000 Bushings for Pre-Punched Hole or 1-11/32 (34.1 mm) Diameter Hole Punched by 710 Cat No: 712A1000 UPC No: 783310059288 Description • • • • Triple lock design holds bushing securely Locks securely into metal studs from 24 gauge to 12 gauge (0.6 mm to 2.5 mm) Helps protect wire insulation from sharp edges of metal studs Makes pulling smooth and easy by preventing hang-ups of cable on raw metal edges Specifications • • • • • Application : For Metal Stud Punches Package : 1000/Bag Size : 1-11/32 IN (34.100 MM) Standard : CSA Certified, C/US UL Listed Weight : 15.500 LB (7.000 KG)
712A1000 价格&库存
很抱歉,暂时无法提供与“712A1000”相匹配的价格&库存,您可以联系我们找货
