11-304-C
11-304-C
    GCELECTRONICS
11-304-C 数据手册
HARDWARE GROMMET AND HOLE PLUG KITS 210 Pieces 63 Pieces Hardware 185 Pieces HD-4209 Vinyl Grommet Kit HD-4211 Hole Plug Kit HD-4210 Rubber Grommet Kit Kit No. HD-4209 Vinyl Grommet Kit for 1/4”, 5/16”, 3/8”, 7/16”, 1/2” and 5/8” Mount Holes. Refill Part No. G-401 G-402 G-403 G-404 G-405 G-406 Quantity Per Kit Description 70 40 25 20 20 10 Vinyl Vinyl Vinyl Vinyl Vinyl Vinyl Grommet Grommet Grommet Grommet Grommet Grommet Mounting Hole (Inches) Panel Thickness (Inches) Thickness (Inches) 1/4 5/16 3/8 7/16 1/2 5/8 1/16 1/16 1/16 1/16 1/16 1/16 3/16 7/32 1/4 1/4 1/4 9/32 Inner Diameter (Inches) 1/8 3/16 1/4 5/16 3/8 1/2 Outer Diameter (Inches) 11/32 7/16 9/16 5/8 5/8 13/16 Kit No. HD-4210 Rubber Grommet Kit for 1/4”, 5/16”, 3/8”, 1/2”, 5/8” and 3/4” Mount Holes. Refill Part No. 11-284-C G-305 11-292-BU 11-300-BU 11-304-BU 11-308-BU Quantity Per Kit Description 100 40 30 20 10 10 Rubber Rubber Rubber Rubber Rubber Rubber Grommet Grommet Grommet Grommet Grommet Grommet Mounting Hole (Inches) Panel Thickness (Inches) Thickness (Inches) 1/4 5/16 3/8 1/2 5/8 3/4 1/16 1/16 1/16 1/16 1/16 1/16 3/16 7/32 1/4 1/4 9/32 15/64 Inner Diameter (Inches) Kit No. HD-4211 Nickel-plated Snap Button Hole Plug Kit for 1/4”, 3/8”, 1/2”, 3/4” and 1” Mount Holes. Refill Part No. HP-1 HP-2 HP-3 HP-4 HP-5 11-392-C 162 Mounting Hole (Inches) Quantity Description Per Kit 25 15 10 5 5 3 Nickel-plated Nickel-plated Nickel-plated Nickel-plated Nickel-plated Nickel-plated Hole Plug Hole Plug Hole Plug Hole Plug Hole Plug Screen Vent Hole Plug 1/4 3/8 1/2 3/4 1 1 Phone (815)316-9080•Fax (815)316-9081 All quantities are single; BU’s are packages of 10 Unless otherwise noted. 1/8 3/16 1/4 3/8 1/2 9/16 Outer Diameter (Inches) 11/32 7/16 9/16 5/8 13/16 7/8 HARDWARE GROMMETS and HOLE PLUGS Fig. 2 Fig. 1 Grommets CLAMSHELL Qty Part No. KG-401 KG-402 KG-403 KG-404 KG-405 KG-406 KG-407 Qty G-302-P 50 G-307-P 50 G-311-P 11-284-BU 11-292-BU 11-300-BU 11-304-BU 11-308-BU 11-312-BU 11-316-BU 25 10 10 10 10 10 10 10 15 10 10 10 10 5 4 BULK Part No. Qty G-300-C 100 G-305H-C 100 G-309-C 100 11-284-C 11-292-C 11-300-C 11-304-C 11-308-C 11-312-C 11-316-C G-401-C G-402-C G-403-C G-404-C G-405-C G-406-C G-407-C 100 100 100 100 100 100 100 100 100 100 100 100 100 100 N.S.N. No. 5325-00-975-1803 5325-00-682-2080 5325-00-202-2515 5340-00-814-5884 5325-00-474-7083 5325-00-071-3189 Fig. No. Description 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 1 Rubber Grommet 2 Vinyl Grommet 2 Vinyl Grommet 2 Vinyl Grommet 2 Vinyl Grommet 2 Vinyl Grommet 2 Vinyl Grommet 2 Vinyl Grommet Mount Hole (Inches) 1/4 1/2 5/16 19/32 15/32 7/8 1/4 3/8 1/2 5/8 3/4 7/8 1 1/4 5/16 3/8 7/16 1/2 5/8 7/8 Panel Thickness Thickness Diameter (Inches) Outer Inner (Inches) (Inches) 11/32 1/16 1/8 3/16 21/32 1/16 3/8 1/4 7/16 1/16 3/16 3/16 3/4 3/64 7/16 1/4 5/8 1/16 11/32 1/4 1-1/8 1/16 5/8 5/16 11/32 1/16 1/8 3/16 9/16 1/16 1/4 1/4 5/8 1/16 3/8 1/4 13/16 1/16 1/2 9/32 7/8 1/16 9/16 15/64 1-1/8 1/16 5/8 5/16 1-5/16 1/16 11/16 3/8 11/32 1/16 1/8 3/16 7/16 1/16 3/16 7/32 9/16 1/16 1/4 1/4 5/8 1/16 5/16 1/4 5/8 1/16 3/8 1/4 13/16 1/16 1/2 9/32 1-1/8 1/16 5/8 9/32 Fig. 4 Fig. 3 Hole Plugs CLAMSHELL Qty Part No. KHP-1 KHP-2 KHP-3 KHP-4 KHP-5 8 4 6 5 3 POLYBAG Part No. HP-4-P HP-5-P Qty BULK Part No. Qty HP-1-C HP-2-C HP-3-C 100 100 100 11-344-C 11-348-C 11-356-C 11-360-C 11-364-C 11-368-C 11-388-C 11-392-C 100 100 100 100 100 100 100 100 N.S.N. No. 50 25 5340-00-816-3421 5340-00-782-8713 5340-00-816-3423 5340-00-816-3424 5340-00-587-1331 Fig. No. Description 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 3 Steel, Nickel Plated Hole Plug 4 Steel, Nickel Plated Screened Vent Hole Plug For the latest information–www.gcelectronics.com All quantities are single; BU’s are packages of 10 Unless otherwise noted. Mount Hole (Inches) 1/4 3/8 1/2 3/4 1 1/4 5/16 1/2 5/8 3/4 7/8 1 1 163 Hardware 8 KG-302 POLYBAG Part No.
11-304-C 价格&库存
很抱歉,暂时无法提供与“11-304-C”相匹配的价格&库存,您可以联系我们找货
