181-13006
181-13006
    HELLERMAN(海尔曼太通)
181-13006 数据手册
SLA1X1W4 Slotted Wall Duct - 1" X 1" Adhesive, PVC, White, 120' / carton Article Number: 181-11021 Part Number: SLA1X1W4 Type: SLA1X1 Material: PVC 1. Base Data Part No. SLA1X1W4 Type SLA1X1 Color White 2. Product Dimensions Length (L) 6 ft / 1.83 m Width (W) 1.00 " / 25.4 mm Width (W2) 1.00 " / 25.4 mm Width (W3) 10.2 mm Width (W4) 1.00 " / 25.4 mm Width (W5) .75 " / 19.1 mm Height (H) 1.05 " / 26.7 mm Mounting Hole Centers 4.00 " / 101.60 mm 4. Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Certification CSA CSA Certified Yes Flammability self-extinguishing Operating Temperature +122 °F (+50 °C) Logistic and Packaging Packaging Type carton Pkg. Qty. 120 ft / 36.6 m Carton Qty. 120 ft UPC 08930604757 Miscellaneous UL Recognized (US and Canada) Yes Width (W3) .40 " Routing and Protecting Wiring Duct Pro-Duct Wiring Duct HellermannTyton’s Pro-Duct wiring duct efficiently routes and protects wire and cable. Manufactured from high impact, rigid PVC, Pro-Duct includes solid, slotted and high density slotted styles. Available in over 28 sizes, Pro-Duct comes in standard colors of white, gray and black in 6 foot lengths. Blue wiring duct is also available in a variety of standard sizes. Other colors are available. Contact HellermannTyton for minimum volume requirements. Pro-Duct Features All styles of Pro-Duct wiring duct (solid, slotted and high density slotted) are designed with many installer preferred features: - Smooth edges protect installer and wires from abrasion. - Cover is flush with the side of the duct for increased wire capacity. It also allows for tight, side-by-side placement. - No cover slippage. The covers are provided with a non-slip plastic lining. This ensures that the covers remain in place during vibration, yet they easily snap on and off, offering ready access to the wire run. - Mounting holes are designed for installation versatility. Elongated mounting holes allow for changes in panel designs and installation flexibility. - Mounting holes are standard. Contact HellermannTyton for duct without mounting holes. - Enhanced wire capacity helps maximize space within panels. - Interchangeable covers between solid, slotted, and high density slotted styles reduce inventory and increase versatility. - Professional appearance increases panel’s overall neatness. Pro-Duct is U.L. Recognized, CSA Certified, and carries a U.L. flame rating of 94V0. File # E64139 Solid Wall Duct Solid wall duct is designed for straight wire runs where break-outs are not required. - Smooth edges - Non-slip cover - Professional appearance Slotted Wall Duct Slotted wall duct features break-away fingers which provide additional access for wire leads. Slotted wall duct is manufactured with two score lines. The first score line is at the base of the finger, allowing the finger to be bent and broken away when a greater opening is required. The second score line is lower allowing a section of the sidewall to be easily removed by cutting the sidewall down to the lower score line. Use HellermannTyton’s TDNT notching tool and snap out the desired section. Both score lines provide smooth edges to ensure worker safety. Strong fingers prevent unwanted breaking. The fingers are easily deflected outward, allowing ready positioning of the wires within the slotted wall duct. Restricted opening design in the finger of the duct helps keep wires in place. Restriction also prevents unintended removal of wires and permits any individual wire to be traced without disconnection. 102 File # 49249 Routing and Protecting Wiring Duct Slotted Wall Duct File # E64139 Product Selection Article No. Part No. Width (W) Height (H) Width (W2) Width (W3) Width Width Width (W4) (W5) (W6) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) Pkg. Qty. Description Color ft. (6 ft. lengths) Non-Adhesive White 120 ft Adhesive White 120 ft Non-Adhesive Gray 120 ft Adhesive Gray 120 ft SL1x1 Non-Adhesive Black 120 ft SLA1X1 Adhesive Black 120 ft Non-Adhesive White 120 ft Adhesive White 120 ft Non-Adhesive Gray 120 ft Type in. (mm) File # 49249 1″″ x 1″″ (25.4 x 25.4) Nominal Duct Size 181-11015 SL1X1W4 181-11021 SLA1X1W4 181-11013 SL1X1G4 181-11019 SLA1X1G4 181-11009 SL1X1BK4 181-11016 SLA1X1BK4 SL1x1 SLA1X1 SL1x1 1.00″ (25.4) SLA1X1 1.05″ (26.7) 1.00″ (25.4) .40″ (10.2) One row of 1.00″ .75″ holes (25.40) (19.05) on 1″″ x 1.5″″ (25.4 x 38.1) Nominal Duct Size 181-11507 SL1X1.5W4 181-11511 SLA1X1.5W4 181-11505 SL1X1.5G4 SL1X1.5 SLA1X1.5 SL1X1.5 1.02″ (25.91) 1.56″ (26.1) 1.00″ .40″ 1.00″ (25.40) (10.16) (25.40) One row of 1.19″ holes (30.2) on 181-11509 SLA1X1.5G4 SLA1X1.5 Adhesive Gray 120 ft 181-00552 SL1X1.5BK4 SL1X1.5 Non-Adhesive Black 120 ft SLA1X1.5 Adhesive Black 120 ft Non-Adhesive White 120 ft Adhesive White 120 ft Non-Adhesive Gray 120 ft 181-00564 SLA1X1.5BK4 1″″ x 2″″ (25.4 x 50.8) Nominal Duct Size 181-12008 SL1X2W4 181-12013 SLA1X2W4 181-12005 SL1X2G4 SL1X2 SLA1X2 SL1X2 1.03″ (26.16) 2.06″ (52.32) 1.00″ .40″ 1.00″ (25.40) (10.16) (25.40) One row of 1.62″ holes on (41.1) 181-12011 SLA1X2G4 SLA1X2 Adhesive Gray 120 ft 181-00024 SL1X2BK4 SL1X2 Non-Adhesive Black 120 ft SLA1X2 Adhesive Black 120 ft Non-Adhesive White 120 ft Adhesive White 120 ft Non-Adhesive Gray 120 ft 181-00565 SLA1X2BK4 1″″ x 3″″ (25.4 x 76.2) Nominal Duct Size 181-13008 SL1X3W4 181-13012 SLA1X3W4 181-13006 SL1X3G4 SL1X3 SLA1X3 SL1X3 1.02″ (25.91) 3.06″ (77.72) 1.00″ .40″ 1.00″ (25.40) (10.16) (25.40) One row of 2.60″ holes on (66.0) 181-13010 SLA1X3G4 SLA1X3 Adhesive Gray 120 ft 181-13003 SL1X3BK4 SL1X3 Non-Adhesive Black 120 ft SLA1X3 Adhesive Black 120 ft Non-Adhesive White 120 ft Adhesive White 120 ft Non-Adhesive Gray 120 ft 181-00566 SLA1X3BK4 1″″ x 4″″ (25.4 x 101.6) Nominal Duct Size 181-14006 SL1X4W4 181-00569 SLA1X4W4 181-14003 SL1X4G4 SL1X4 SLA1X4 SL1X4 1.00″ (25.40) 4.06″ (103.12) 1.00″ .40″ 1.00″ (25.40) (10.16) (25.40) One row of holes 3.6″ on (91.4) 181-00568 SLA1X4G4 SLA1X4 Adhesive Gray 120 ft 181-14001 SL1X4BK4 SL1X4 Non-Adhesive Black 120 ft SLA1X4 Adhesive Black 120 ft Non-Adhesive White 120 ft Adhesive White 120 ft Non-Adhesive Gray 120 ft 181-00567 SLA1X4BK4 1.5″″ x 1″″ (38.1 x 25.4) Nominal Duct Size 181-15107 SL1.5X1W4 181-00572 SLA1.5X1W4 181-15105 SL1.5X1G4 SL1.5X1 SLA1.5X1 SL1.5X1 1.50″ (38.10) 1.05″ (26.67) 1.50″ .40″ 1.00″ (38.10) (10.16) (25.40) One row of holes .75″ on (19.1) 181-00571 SLA1.5X1G4 SLA1.5X1 Adhesive Gray 120 ft 181-00548 SL1.5X1BK4 SL1.5X1 Non-Adhesive Black 120 ft SLA1.5X1 Adhesive Black 120 ft 181-00570 SLA1.5X1BK4 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Slotted wall duct in larger sizes continued on the next page. Covers are listed on page 117. 109
181-13006 价格&库存
很抱歉,暂时无法提供与“181-13006”相匹配的价格&库存,您可以联系我们找货
