181-00550
181-00550
    HELLERMAN(海尔曼太通)
181-00550 数据手册
Home Worldwide Events Careers How To Buy Products Cable Ties Search Contact Industries Resources News About Us SL1.5X3BK4 Cable Ties with Fasteners Find a Distributor Slotted Wall Duct - 1.5"" X 3"" Non - Adhesive, PVC, Black, 120' / carton Cable Tie Tools Order Samples Clamps and Clips Mounts Article Number: 181 - 00550 Heavy Duty Mounts Part Number: SL1.5X3BK4 Wiring Duct Type: SL1.5X3 Material: PVC Solid Wall Get Technical Drawings Slotted Wall High Density Slotted Wall Covers Accessories Wiring Protection Labels, Printers and Software Pre - Terminated Networking 1. Base Data Copper Network Solutions Fiber Network Solutions Jacks and Wall Plates Part No. SL1.5X3BK4 Type SL1.5X3 Color Black (BK) Features Slotted wall duct features break - away fingers which provide additional access for wire leads. Slotted wall duct is manufactured with two score lines. The first score line is at the base of the finger, allowing the finger to be bent and broken away when a greater opening is required. The second score line is lower allowing a section of the sidewall to be easily removed by cutting the sidewall down to the lower score line. Use HellermannTytonâ €™s TDNT notching tool and snap out the desired section. Both score lines provide smooth edges to ensure worker safety. Strong fingers prevent unwanted breaking. The fingers are easily deflected outward, allowing ready positioning of the wires within the slotted wall duct. Restricted opening design in the finger of the duct helps keep wires in place. Restriction also prevents unintended removal of wires and permits any individual wire to be traced without disconnection. Residential Solutions Racks - Cable Management Surface Raceway Systems 2. Product Dimensions Length (L) 6 ft / 1.83 m Width (W) 1.52 " / 38.61 mm Width (W2) 1.50 " / 38.10 mm Width (W3) 10.16 mm Width (W4) 1.00 " / 25.40 mm Width (W5) 2.60 " / 66.0 mm Height (H) 3.06 " / 77.72 mm Mounting Hole Centers 4.00 " / 101.60 mm 4. Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Certification CSA / UL CSA Certified Yes Flammability self - extinguishing Material Specification RoHS Operating Temperature +122 °F (+50 °C) Logistic and Packaging Packaging Type carton Pkg. Qty. 120 ft / 36.6 m Carton Qty. 120 UPC 08930626378 Miscellaneous UL Recognized (US and Canada) Yes Width (W3) .40 " Find a Distributor Get Product Samples Get Technical Drawings Customers Who Bought This Item Also Bought Wiring Duct Cover Width 1.50"" PVC, Black, 120' / Pkg. Qty. Part No: TC1.5BK4 Article No: 181 - 91503 Slotted Wall Duct - 2"" X 3"" Non - Adhesive, PVC, Black, 120' / carton Part No: SL2X3BK4 Article No: 181 - 23003 6"" Grip Tie - .5"" wide - Black Part No: GT.50X60P2 Article No: 854 - 44339 6"" Grip Tie - .5"" wide - Black Part No: GT.50X60P2 Article No: 854 - 44339 This product was foundWiring in Duct> Slotted Wall Home About HellermannTyton Products Careers Contact Terms © HellermannTyton North America 2008 TS16949:2002 , ISO 9001:2000 7930 N. Faulkner Rd. Milwaukee, WI 53224 - 9517 Fax: 800 - 848 - 9866 and ISO14001 Certified Phone: 800 - 537 - 1512
181-00550 价格&库存
很抱歉,暂时无法提供与“181-00550”相匹配的价格&库存,您可以联系我们找货
