1487CB60
1487CB60
    HAMMONDMANUFACTURING
1487CB60 数据手册
5/10/23, 9:01 AM Type 12 Pull Through Wireway (1487 Series) - Hammond Mfg. Quality Products. Service Excellence. Type 12 Pull Through Wireway 1487 Series Wireway & Accessories Application   Designed to enclose and protect electrical wiring from dirt, dust, oil and water. Ideal for connecting machines to control panels or power sources. Standards UL 870 Type 1, 12 (unless marked¹) CSA Type 1, 12 (unless marked¹) Complies with NEMA Type 1, 12 IEC 60529, IP54 Construction Bodies and covers are formed from 14 gauge steel with 10 gauge steel flanges. Continuous flange around wireway ends, requires cables to be pulled through. (For lay-in style, see 1485 Series.) Smooth continuously welded seams. Interior surfaces are smooth to prevent wire damage during installation. Butt hinged covers are secured with easily operated screw clamps. Oil resistant gaskets are permanently secured. Solid oil resistant gaskets are used between flanges when sections and fittings are bolted together. One gasket kit, complete with hardware is provided with each straight section or fitting. Finish Sections and fittings are finished in ANSI 61 gray. Accessories Typical Straight Section Barrier Kit Nipple Flexible Fitting Cut-Off Fitting (Lay-In) 45 degree Elbow Tee Fitting Drop Hanger Swivel Nipple Adjustable Fitting 90 degree Elbow 22.5 degree Elbow Box Connector Bracket Hanger Cross Fitting Reducers (Center Hole) Cover Plate Reducers (Edge Hole) https://www.hammfg.com/electrical/products/wireway/1487 1/3 5/10/23, 9:01 AM Type 12 Pull Through Wireway (1487 Series) - Hammond Mfg. 2.5 x 2.5 4x4 6x6 8x8 Description Part No. Part No. Part No. Part No. 12" Section 1487B12 1487C12 1487D12 1487E12 24" Section 1487B24 1487C24 1487D24 1487E24 36" Section 1487B36 1487C36 1487D36 1487E36 48" Section 1487B48 1487C48 1487D48 1487E48 60" Section 1487B60 1487C60 1487D60 1487E60 120" Section 1487B120 1487C120 1487D120 1487E120 60" Long Partition (Barrier) - 1487CB60¹ 1487DB60¹ 1487EB60¹ 1" Nipple 1487BM1 1487CM1 1487DM1 1487EM1 2" Nipple 1487BM2 1487CM2 1487DM2 1487EM2 3" Nipple 1487BM3 1487CM3 1487DM3 1487EM3 6" Nipple 1487BM6 1487CM6 1487DM6 1487EM6 Box Entry Swivel Nipple 1487BV1 1487CV1 1487DV1 1487EV1 Standard Swivel Nipple 1487BV2 1487CV2 1487DV2 1487EV2 Flexible Fitting 1485BFF¹ 1485CFF¹ 1485DFF¹ 1485EFF¹ Adjustable Fitting 1487BX¹ 1487CX¹ 1487DX¹ 1487EX¹ Cut-Off Fitting 1487BW¹ 1487CW¹ 1487DW¹ 1487EW¹ 90° Elbow 1487B9P 1487C9P 1487D9P 1487E9P 45° Elbow 1487B4P 1487C4P 1487D4P 1487E4P 22.5° Elbow 1487B2P 1487C2P 1487D2P 1487E2P Tee Fitting 1487BT 1487CT 1487DT 1487ET Cross Fitting 1487BY 1487CY 1487DY 1487EY Reducer - 4 x 4 to 2.5 x 2.5 - 1487CRC² - - Reducer - 6 x 6 to 4 x 4 - - 1487DRC² - Reducer - 8 x 8 to 4 x 4 - - - 1487ERCC² Reducer - 8 x 8 to 6 x 6 - - - 1487ERCD² Reducer 4 x 4 to 2.5 x 2.5 - 1487CRE² - - Reducer 6 x 6 to 4 x 4 - - 1487DRE² - Reducer 8 x 8 to 4 x 4 - - - 1487EREC² Reducer 8 x 8 to 6 x 6 - - - 1487ERED² Box Connector 1487BK¹ 1487CK¹ 1487DK¹ 1487EK¹ Drop Hanger 1485BL1¹ 1485CL1¹ 1485DL1¹ 1485EL1¹ Bracket Hanger 1485BL2¹ 1485CL2¹ 1485DL2¹ 1485EL2¹ Cover Plate 1487BH² 1487CH² 1487DH² 1487EH² Gasket & Screws 1487BS¹ 1487CS¹ 1487DS¹ 1487ES¹ Center Hole Reducers Edge Hole Reducers ¹ Does not meet CSA or UL requirements ² Maintains ratings on CSA and UL approved wireway Tags: wireway, section, pull through, steel, Type 12, NEMA 12 https://www.hammfg.com/electrical/products/wireway/1487 Data subject to change without notice 2/3 5/10/23, 9:01 AM Type 12 Pull Through Wireway (1487 Series) - Hammond Mfg. © 2023. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electrical/products/wireway/1487 3/3
1487CB60 价格&库存
很抱歉,暂时无法提供与“1487CB60”相匹配的价格&库存,您可以联系我们找货
1487CB60
  • 1+599.841571+77.84849
