184-23004
184-23004
    HELLERMAN(海尔曼太通)
    HDSLOTTEDDUCT2X36'
184-23004 数据手册
Home Worldwide Events Careers How To Buy Products Cable Ties Search Contact Industries Resources News About Us SLHD2X3G4 Cable Ties with Fasteners Find a Distributor High Density Slotted Duct - 2"" X 3"" Non-Adhesive, PVC, Gray, 120' / carton Cable Tie Tools Order Samples Clamps and Clips Mounts Article Number: 184 - 23004 Heavy Duty Mounts Part Number: SLHD2X3G4 Wiring Duct Type: SLHD2X3 Material: PVC Solid Wall Get Technical Drawings Slotted Wall High Density Slotted Wall Covers Accessories Wiring Protection Labels, Printers and Software Pre - Terminated Networking 1. Base Data Copper Network Solutions Fiber Network Solutions Jacks and Wall Plates Part No. SLHD2X3G4 Type SLHD2X3 Color Gray Features High density slotted wall duct comes with narrow fingers, equaling a 2 - to - 1 finger ratio compared to standard slotted wiring duct. Narrow fingers reduce fanning of the wires to the terminal blocks. Compact designs and components are more easily accommodated with the high density ductâ €™s 2 - to - 1 finger ratio. High density duct also incorporates the double scored design, similar to the standard slotted wall duct. With sizes 2â €? high and above, high density duct features a double restriction on each finger of the duct. The double restriction helps retain wires in the bottom portion of the duct for easier installation. Mounting holes are uniform in size to the solid and slotted wall duct, but are offered every 2 inches to accommodate compact designs and installations. Residential Solutions Racks - Cable Management Surface Raceway Systems 2. Product Dimensions Length (L) 6 ft / 1.83 m Width (W) 2.02 " / 51.3 Width (W2) 2.00 " / 50.8 mm Width (W3) 4.1 mm Width (W4) .40 " / 10.2 mm Width (W5) 2.60 " / 66.0 mm Width (W6) .50 " / 12.7 mm Height (H) 3.06 " / 77.7 mm Mounting Hole Centers 2.00 " / 50.80 mm 4. Material and Specifications Material Polyvinylchloride (PVC) Material Shortcut PVC Certification CSA / UL CSA Certified Yes Flammability self - extinguishing Material Specification RoHS Operating Temperature +122 °F (+50 °C) Logistic and Packaging Packaging Type carton Pkg. Qty. 120 ft / 36.6 m Carton Qty. 120 UPC 08930611397 Miscellaneous UL Recognized (US and Canada) Yes Width (W3) .16 " Find a Distributor Get Product Samples Get Technical Drawings Customers Who Bought This Item Also Bought Wiring Duct Cover Width 2.00"" PVC, Gray, 120' / Pkg. Qty. Part No: TC2G4 Article No: 181 - 92005 Wiring Duct Cover Width 1.50"" PVC, Gray, 120' / Pkg. Qty. Part No: TC1.5G4 Article No: 181 - 91507 High Density Slotted Duct - 1"" X 3"" Non - Adhesive, PVC, Gray, 120' / carton Part No: SLHD1X3G4 Article No: 184 - 13005 Wiring Duct Cover Width 1.00"" PVC, Gray, 120' / Pkg. Qty. Part No: TC1G4 Article No: 181 - 91004 Wiring Duct Cover Width 3.00"" PVC, Gray, 120' / Pkg. Qty. Part No: TC3G4 Article No: 181 - 93008 This product was foundWiring in Duct> High Density Slotted Wall Home About HellermannTyton Products Careers Contact Terms © HellermannTyton North America 2008 TS16949:2002 , ISO 9001:2000 7930 N. Faulkner Rd. Milwaukee, WI 53224 - 9517 Fax: 800 - 848 - 9866 and ISO14001 Certified Phone: 800 - 537 - 1512
184-23004 价格&库存
很抱歉,暂时无法提供与“184-23004”相匹配的价格&库存,您可以联系我们找货
