ADVANCED ENGINEERING
METAL & SHIELDING
Technical Data Sheet
Put-Ups
E
MI, RFI, ESD Protection
G
rounding Straps
E
ngine Dress-Up
C
omplies With
CID A-A-59569
E
xtreme Blowout
Protection
E
xpands For Easy
Installation
C
ut And Abrasion
Resistant
Nominal
Size
Part
Wall
Thickness
Wire
Thickness
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/16”
7/64”
1/8”
5/32”
11/64”
13/64”
1/4”
3/8”
1/2”
5/8”
25/32”
7/8”
1”
1 1/8”
1 1/4”
1 3/8”
1 1/2”
2”
2 1/4”
MBN0.06SV
MBN0.11SV
MBN0.13SV
MBN0.16SV
MBN0.17SV
MBN0.20SV
MBN0.25SV
MBN0.38SV
MBN0.50SV
MBN0.63SV
MBN0.78SV
MBN0.88SV
MBN1.00SV
MBN1.13SV
MBN1.25SV
MBN1.38SV
MBN1.50SV
MBN2.00SV
MBN2.25SV
0.013”
0.013"
0.013”
0.013”
0.013”
0.020"
0.013”
0.013”
0.013”
0.016”
0.013”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.005”
0.005"
0.005”
0.005”
0.005”
0.008"
0.005”
0.005”
0.005”
0.006”
0.005”
0.010”
0.010”
0.010”
0.010”
0.010”
0.010”
0.010”
0.010”
250’
250'
250’
250’
250’
250'
250’
250’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100'
100’
100’
100’
100'
100’
100’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
50’
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
0.40
0.80
1.00
2.10
1.35
2.50
2.20
3.30
3.50
3.60
7.35
10.30
13.15
13.80
16.50
16.90
18.40
22.70
23.60
Tinned Copper Sleeve For Shielding,
Grounding And Decoration.
Provides Shield Coverage
of 90% Minimum!
Cut Cleanly
Scissors
Material
Tinned Copper
Grade
MBN
Wire Thickness
.005” - .010”
Our skill with braided sleeving extends
to many materials including metal braid
for a variety of applications. Our tinned
copper braid is perfect for shielding
on harnesses and cables. Wire conforms
to ASTM-B 33.
The material is also great for hose covering
on hot rods and motorcycles.
(This product was previous known as Metal Braid.)
www.techflex.com
800.323.5140 • 973.300.9242 • fax: 973.300.9409
104 Demarest Road • Sparta, NJ 07871
Colors Available:
Silver (SV)
METAL & SHIELDING
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
Copper 1,981°F (1,083°C)
Tin 450°F (232°C)
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________________ 1
Aliphatic Solvents___________________________ 1
Chlorinated Solvents________________________ 1
Weak Bases________________________________ 1
Salts______________________________________ 1
Strong Bases_______________________________ 2
Salt Water 0-S-1926__________________________ 1
Hydraulic Fluid MIL-H-5606___________________ 1
Lube Oil MIL-L-7808_________________________ 1
De-Icing Fluid MIL-A-8243____________________ 1
Strong Acids_______________________________ 5
Strong Oxidants____________________________ 5
Esters/Ketones_____________________________ 1
UV Light__________________________________ 2
Petroleum_________________________________ 2
Fungus ASTM G-21__________________________ 2
Halogen Free____________________________ Yes
RoHS___________________________________ Yes
Part
AWG
of Ends
Carriers
Wires
Per
Carrier
1/16"
MBN0.06SV
36
24
2
7/64"
MBN0.11SV
36
24
4
1/8"
MBN0.13SV
36
24
5
5/32"
MBN0.16SV
36
24
10
11/64”
MBN0.17SV
36
24
7
13/64"
MBN0.20SV
32
24
5
1/4"
MBN0.25SV
36
24
16
3/8"
MBN0.38SV
36
48
8
1/2"
MBN0.50SV
36
48
11
*5/8"
MBN0.63SV
34
48
8
25/32"
MBN0.78SV
36
48
18
7/8"
MBN0.88SV
30
48
7
1”
MBN1.00SV
30
48
8
1 1/8”
MBN1.13SV
30
48
9
*1 1/4”
MBN1.25SV
30
48
10
1 3/8”
MBN1.38SV
30
48
11
1 1/2”
MBN1.50SV
30
48
12
2”
MBN2.00SV
30
48
14
*2 1/4”
MBN2.25SV
30
48
16
*Not on Spec - CID A-A-59569 (formerly Mil Spec QQB-575)
Current
Capacity
Amps
11
19
25
40
32
46
53
53
62
64
88
100
120
130
145
150
165
180
190
PHYSICAL
PROPERTIES
Monofilament Diameter_______________ .005”-.010”
ASTM D-204
Flammability Rating______________ Non Flammable
Recommended Cutting___________________ Shears
Colors______________________________________1
Wall Thickness______________________ .013”-.025”
Specific Gravity ASTM D-792_________________ 8.9
Moisture Absorption________________________ NA
% ASTM D-570
FLAMMABILITY
Rating_________________________ Non Flammable
© 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
01-08
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
CHEMICAL
RESISTANCE
Nominal
Size
很抱歉,暂时无法提供与“MBN1.00SV50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2763.340181+343.86865
- 2+2541.460542+316.25806
- 3+2420.030793+301.14740
- 5+2275.328845+283.14076
- 7+2184.794277+271.87469
- 10+2092.7346510+260.41884
- 25+1873.7102525+233.16355
- 50+1723.4198450+214.46149
