MBC0.25CP25
MBC0.25CP25
    TECHFLEX
    1/4"COPPERBRAID25'
MBC0.25CP25 数据手册
ADVANCED ENGINEERING METAL & SHIELDING Technical Data Sheet Technical Data Sheet Put Ups Perfect for Grounding and Shielding 100% Copper Braid P  rovides Excellent Current Transmission Nominal Size Part # Wall Thickness Min Exp. Max Exp. Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/2” 2 1/4” MBC0.13CP MBC0.25CP MBC0.38CP MBC0.50CP MBC0.75CP MBC1.00CP MBC1.50CP MBC2.25CP .015” .025” .018” .020” .025” .040” .055” .060” 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/2” 2 1/4” 1/4” 3/8” 3/4” 1” 1 1/4” 1 3/4” 2 1/8” 3 3/16” 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ Copper Copper Copper Copper Copper Copper Copper Copper 0.90 3.00 3.10 4.10 7.90 14.00 20.00 26.00 Bare Copper Braid for a Wide Variety of Applications! Cut Cleanly Shears Techflex® high purity Copper Sleeve is a 100% copper braid for grounding , shielding, and many other unique projects. Our copper series of metal braids are pure metal with no fillers or coating to provide many years of continuous use. Our braid is suitable for hoses, wires, and other lines on a wide variety of applications. Techflex® Bar Copper braid will provide high flexibility and excellent current transmission for your demanding uses. Material Copper Grade MBC Wall Thickness 0.15”- 0.55” Drawing Number TF001MBC-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: Copper (CP) METAL & SHIELDING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 FLAMMABILITY 1,981°F (1,083°C) www.techflex.com Rating______________________ Non Flammable CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________________ 1 Aliphatic Solvents___________________________ 1 Chlorinated Solvents________________________ 1 Weak Bases________________________________ 1 Salts______________________________________ 1 Strong Bases_______________________________ 2 Salt Water 0-S-1926__________________________ 1 Hydraulic Fluid MIL-H-5606___________________ 1 Lube Oil MIL-L-7808_________________________ 1 De-Icing Fluid MIL-A-8243____________________ 1 Strong Acids_______________________________ 5 Strong Oxidants____________________________ 5 Esters/Ketones_____________________________ 1 UV Light__________________________________ 2 Petroleum_________________________________ 2 Fungus ASTM G-21__________________________ 2 Halogen Free____________________________ Yes RoHS___________________________________ Yes PHYSICAL PROPERTIES Monofilament Thickness____________________.005” ASTM D-204 Flammability Rating______________ Non Flammable Recommended Cutting___________________ Shears Colors______________________________________1 Wall Thickness_________________________.015-.055” © 2022 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-22 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
MBC0.25CP25 价格&库存
很抱歉,暂时无法提供与“MBC0.25CP25”相匹配的价格&库存,您可以联系我们找货
