ADVANCED ENGINEERING
METAL & SHIELDING
Technical Data Sheet
Put Ups
Perfect for Grounding
and Shielding
100% Copper Braid
P
rovides Excellent
Current Transmission
Nominal
Size
Part
Wall
Thickness
Min
Exp.
Max
Exp.
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/2”
2 1/4”
MBC0.13CP
MBC0.25CP
MBC0.38CP
MBC0.50CP
MBC0.75CP
MBC1.00CP
MBC1.50CP
MBC2.25CP
.015”
.025”
.018”
.020”
.025”
.040”
.055”
.060”
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/2”
2 1/4”
1/4”
3/8”
3/4”
1”
1 1/4”
1 3/4”
2 1/8”
3 3/16”
250’
100’
100’
100’
100’
100’
100’
100’
25’
25’
25’
25’
25’
25’
25’
25’
Copper
Copper
Copper
Copper
Copper
Copper
Copper
Copper
0.90
3.00
3.10
4.10
7.90
14.00
20.00
26.00
Bare Copper Braid for a Wide
Variety of Applications!
Cut Cleanly
Shears
Techflex® high purity Copper Sleeve is a
100% copper braid for grounding , shielding,
and many other unique projects. Our copper
series of metal braids are pure metal with no
fillers or coating to provide many years of
continuous use. Our braid is suitable for hoses,
wires, and other lines on a wide variety of applications. Techflex® Bar Copper braid will provide high
flexibility and excellent current transmission for
your demanding uses.
Material
Copper
Grade
MBC
Wall Thickness
0.15”- 0.55”
Drawing Number
TF001MBC-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Colors Available:
Copper (CP)
METAL & SHIELDING
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
FLAMMABILITY
1,981°F (1,083°C)
www.techflex.com
Rating______________________ Non Flammable
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________________ 1
Aliphatic Solvents___________________________ 1
Chlorinated Solvents________________________ 1
Weak Bases________________________________ 1
Salts______________________________________ 1
Strong Bases_______________________________ 2
Salt Water 0-S-1926__________________________ 1
Hydraulic Fluid MIL-H-5606___________________ 1
Lube Oil MIL-L-7808_________________________ 1
De-Icing Fluid MIL-A-8243____________________ 1
Strong Acids_______________________________ 5
Strong Oxidants____________________________ 5
Esters/Ketones_____________________________ 1
UV Light__________________________________ 2
Petroleum_________________________________ 2
Fungus ASTM G-21__________________________ 2
Halogen Free____________________________ Yes
RoHS___________________________________ Yes
PHYSICAL
PROPERTIES
Monofilament Thickness____________________.005”
ASTM D-204
Flammability Rating______________ Non Flammable
Recommended Cutting___________________ Shears
Colors______________________________________1
Wall Thickness_________________________.015-.055”
© 2022 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-22
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
很抱歉,暂时无法提供与“MBC0.38CP25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+629.366891+81.75157
