MBB0.50BS25
MBB0.50BS25
    TECHFLEX
    Tubular Ground Braid 0.500" (12.70mm, 1/2") - Outer Dia X 25.0' (7.62m)
MBB0.50BS25 数据手册
ADVANCED ENGINEERING METAL & SHIELDING Technical Data Sheet Technical Data Sheet Put Ups Perfect for Decorative Applications Antimicrobial and Germicidal Properties Provides Form and Functionality Nominal Size Part # Wall Thickness Min Exp. Max Exp. Bulk Spool Shop Spool 1/8” 1/4” 3/8” 1/2” MBB0.13BRS MBB0.25BRS MBB0.38BRS MBB0.50BRS .015" .027" .015" .020" 1/8" 1/4" 3/8" 1/2" 1/4" 3/8" 3/4" 1" 250’ 100’ 100’ 100’ 25’ 25’ 25’ 25’ Brass Beauty! Techflex® Flexo Brass can be a useful and beautiful part of your next project. The decorative features of Brass are obvious, but many people don't know that Brass is actually an alloy of Copper and Zinc. Cut Cleanly Scissors Material Brass Our Brass is designed for both looks and functionality and can be adapted to create custom hoses and brake lines. Designers and engineers may also use our Brass braid for its natural antimicrobial and germicidal properties. Contact with our Brass braid can kill harmful microorganisms within minutes. Brass braid has been used in "Steampunk" creations of all kinds to bring the hoses of the industrial revolution back to life today Grade MBB Wall Thickness .015” - .027” Drawing Number TF001MBB-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Available Colors Brass Brass Brass Brass BRS BRS BRS BRS Lbs/ 100’ 0.90 3.00 3.00 4.20 Colors Available: Brass (BRS) METAL & SHIELDING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point FLAMMABILITY ASTM D-2117 1,650°F - 1,720°F (900°C -940°C) www.techflex.com Rating______________________ Non Flammable CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________________ 1 Aliphatic Solvents___________________________ 1 Chlorinated Solvents________________________ 2 Weak Bases________________________________ 1 Salts______________________________________ 1 Strong Bases_______________________________ 5 Salt Water 0-S-1926__________________________ 1 Hydraulic Fluid MIL-H-5606___________________ 1 Lube Oil MIL-L-7808_________________________ 1 De-Icing Fluid MIL-A-8243____________________ 1 Strong Acids_______________________________ 5 Strong Oxidants____________________________ 5 Esters/Ketones_____________________________ 1 UV Light__________________________________ 2 Petroleum_________________________________ 2 Fungus ASTM G-21__________________________ 2 Halogen Free____________________________ Yes RoHS___________________________________ Yes PHYSICAL PROPERTIES Monofilament Thickness____________________.005” ASTM D-204 Flammability Rating______________ Non Flammable Recommended Cutting___________________ Shears Colors______________________________________1 Wall Thickness_________________________.015-.027” Abrasion Resistance________________________ Med Specific Gravity_____________________________ 8.5 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
MBB0.50BS25 价格&库存
很抱歉,暂时无法提供与“MBB0.50BS25”相匹配的价格&库存,您可以联系我们找货
