MBN0.78SV50
MBN0.78SV50
    TECHFLEX
    25/32"TINCOPPERTBESLEEVE50'
MBN0.78SV50 数据手册
ADVANCED ENGINEERING METAL & SHIELDING Technical Data Sheet Technical Data Sheet Put-Ups E  MI, RFI, ESD Protection G  rounding Straps E  ngine Dress-Up C  omplies With CID A-A-59569 E  xtreme Blowout Protection E  xpands For Easy Installation C  ut And Abrasion Resistant Nominal Size Part # Wall Thickness Wire Thickness Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/16” 7/64” 1/8” 5/32” 11/64” 13/64” 1/4” 3/8” 1/2” 5/8” 25/32” 7/8” 1” 1 1/8” 1 1/4” 1 3/8” 1 1/2” 2” 2 1/4” MBN0.06SV MBN0.11SV MBN0.13SV MBN0.16SV MBN0.17SV MBN0.20SV MBN0.25SV MBN0.38SV MBN0.50SV MBN0.63SV MBN0.78SV MBN0.88SV MBN1.00SV MBN1.13SV MBN1.25SV MBN1.38SV MBN1.50SV MBN2.00SV MBN2.25SV 0.013” 0.013" 0.013” 0.013” 0.013” 0.020" 0.013” 0.013” 0.013” 0.016” 0.013” 0.025” 0.025” 0.025” 0.025” 0.025” 0.025” 0.025” 0.025” 0.005” 0.005" 0.005” 0.005” 0.005” 0.008" 0.005” 0.005” 0.005” 0.006” 0.005” 0.010” 0.010” 0.010” 0.010” 0.010” 0.010” 0.010” 0.010” 250’ 250' 250’ 250’ 250’ 250' 250’ 250’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100' 100’ 100’ 100’ 100' 100’ 100’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver Silver 0.40 0.80 1.00 2.10 1.35 2.50 2.20 3.30 3.50 3.60 7.35 10.30 13.15 13.80 16.50 16.90 18.40 22.70 23.60 Tinned Copper Sleeve For Shielding, Grounding And Decoration. Provides Shield Coverage of 90% Minimum! Cut Cleanly Scissors Material Tinned Copper Grade MBN Wire Thickness .005” - .010” Our skill with braided sleeving extends to many materials including metal braid for a variety of applications. Our tinned copper braid is perfect for shielding on harnesses and cables. Wire conforms to ASTM-B 33. The material is also great for hose covering on hot rods and motorcycles. (This product was previous known as Metal Braid.) www.techflex.com 800.323.5140 • 973.300.9242 • fax: 973.300.9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: Silver (SV) METAL & SHIELDING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 Copper 1,981°F (1,083°C) Tin 450°F (232°C) 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________________ 1 Aliphatic Solvents___________________________ 1 Chlorinated Solvents________________________ 1 Weak Bases________________________________ 1 Salts______________________________________ 1 Strong Bases_______________________________ 2 Salt Water 0-S-1926__________________________ 1 Hydraulic Fluid MIL-H-5606___________________ 1 Lube Oil MIL-L-7808_________________________ 1 De-Icing Fluid MIL-A-8243____________________ 1 Strong Acids_______________________________ 5 Strong Oxidants____________________________ 5 Esters/Ketones_____________________________ 1 UV Light__________________________________ 2 Petroleum_________________________________ 2 Fungus ASTM G-21__________________________ 2 Halogen Free____________________________ Yes RoHS___________________________________ Yes Part # AWG of Ends Carriers Wires Per Carrier 1/16" MBN0.06SV 36 24 2 7/64" MBN0.11SV 36 24 4 1/8" MBN0.13SV 36 24 5 5/32" MBN0.16SV 36 24 10 11/64” MBN0.17SV 36 24 7 13/64" MBN0.20SV 32 24 5 1/4" MBN0.25SV 36 24 16 3/8" MBN0.38SV 36 48 8 1/2" MBN0.50SV 36 48 11 *5/8" MBN0.63SV 34 48 8 25/32" MBN0.78SV 36 48 18 7/8" MBN0.88SV 30 48 7 1” MBN1.00SV 30 48 8 1 1/8” MBN1.13SV 30 48 9 *1 1/4” MBN1.25SV 30 48 10 1 3/8” MBN1.38SV 30 48 11 1 1/2” MBN1.50SV 30 48 12 2” MBN2.00SV 30 48 14 *2 1/4” MBN2.25SV 30 48 16 *Not on Spec - CID A-A-59569 (formerly Mil Spec QQB-575) Current Capacity Amps 11 19 25 40 32 46 53 53 62 64 88 100 120 130 145 150 165 180 190 PHYSICAL PROPERTIES Monofilament Diameter_______________ .005”-.010” ASTM D-204 Flammability Rating______________ Non Flammable Recommended Cutting___________________ Shears Colors______________________________________1 Wall Thickness______________________ .013”-.025” Specific Gravity ASTM D-792_________________ 8.9 Moisture Absorption________________________ NA % ASTM D-570 FLAMMABILITY Rating_________________________ Non Flammable © 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 01-08 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com CHEMICAL RESISTANCE Nominal Size
MBN0.78SV50 价格&库存
很抱歉,暂时无法提供与“MBN0.78SV50”相匹配的价格&库存,您可以联系我们找货
