ADVANCED ENGINEERING
METAL & SHIELDING
Technical Data Sheet
Put Ups
Perfect for Decorative
Applications
Antimicrobial and
Germicidal Properties
Provides Form and
Functionality
Nominal
Size
Part
Wall
Thickness
Min
Exp.
Max
Exp.
Bulk
Spool
Shop
Spool
1/8”
1/4”
3/8”
1/2”
MBB0.13BRS
MBB0.25BRS
MBB0.38BRS
MBB0.50BRS
.015"
.027"
.015"
.020"
1/8"
1/4"
3/8"
1/2"
1/4"
3/8"
3/4"
1"
250’
100’
100’
100’
25’
25’
25’
25’
Brass Beauty!
Techflex® Flexo Brass can be a useful and
beautiful part of your next project. The
decorative features of Brass are obvious,
but many people don't know that Brass is
actually an alloy of Copper and Zinc.
Cut Cleanly
Scissors
Material
Brass
Our Brass is designed for both looks and
functionality and can be adapted to create
custom hoses and brake lines. Designers
and engineers may also use our Brass braid
for its natural antimicrobial and germicidal
properties. Contact with our Brass braid can
kill harmful microorganisms within
minutes.
Brass braid has been used in "Steampunk"
creations of all kinds to bring the hoses of
the industrial revolution back to life today
Grade
MBB
Wall Thickness
.015” - .027”
Drawing Number
TF001MBB-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Available
Colors
Brass
Brass
Brass
Brass
BRS
BRS
BRS
BRS
Lbs/
100’
0.90
3.00
3.00
4.20
Colors Available:
Brass (BRS)
METAL & SHIELDING
ADVANCED
ENGINEERING
Melt Point
FLAMMABILITY
ASTM D-2117
1,650°F - 1,720°F
(900°C -940°C)
www.techflex.com
Rating______________________ Non Flammable
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________________ 1
Aliphatic Solvents___________________________ 1
Chlorinated Solvents________________________ 2
Weak Bases________________________________ 1
Salts______________________________________ 1
Strong Bases_______________________________ 5
Salt Water 0-S-1926__________________________ 1
Hydraulic Fluid MIL-H-5606___________________ 1
Lube Oil MIL-L-7808_________________________ 1
De-Icing Fluid MIL-A-8243____________________ 1
Strong Acids_______________________________ 5
Strong Oxidants____________________________ 5
Esters/Ketones_____________________________ 1
UV Light__________________________________ 2
Petroleum_________________________________ 2
Fungus ASTM G-21__________________________ 2
Halogen Free____________________________ Yes
RoHS___________________________________ Yes
PHYSICAL
PROPERTIES
Monofilament Thickness____________________.005”
ASTM D-204
Flammability Rating______________ Non Flammable
Recommended Cutting___________________ Shears
Colors______________________________________1
Wall Thickness_________________________.015-.027”
Abrasion Resistance________________________ Med
Specific Gravity_____________________________ 8.5
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
很抱歉,暂时无法提供与“MBB0.25BS25”相匹配的价格&库存,您可以联系我们找货
