H2F0.79BK25
H2F0.79BK25
    TECHFLEX
    2:1 FAB HEATSHRINK BLK 20MM 25'
H2F0.79BK25 数据手册
HEATSHRINK TUBING Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups S  hrink Temperature 275°F (135°C) H  ighly Flexible H  alogen Free E  xcellent Chemical Resistance Nominal Size Part # Unshrunk Diameter /mm Shrunk Diameter /mm Put-Ups Bulk Spool Shop Spool 1/2” 3/4” 1 3/16” 1 1/2” 2” 2 3/8” 2 3/4” H2F0.48BK H2F0.79BK H2F1.18BK H2F1.58BK H2F1.97BK H2F2.36BK H2F2.75BK 12 20 30 40 50 60 70 6 10 15 20 25 30 35 100’ 100’ 100’ 100’ 100’ 100’ 100’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ Available Colors Black Black Black Black Black Black Black (BK) (BK) (BK) (BK) (BK) (BK) (BK) Lbs/ 100’ 1.15 1.61 2.13 2.66 3.44 4.11 4.69 S  uperior Abrasion Resistance Over A Wide Temp. Range C  uts Easily With Scissors Fabric 2:1 Heatshrink Tubing Shrinks To 1/2 its Original Diameter! 2:1 Fabric Heatshrink tubing, a unique mixture of Polyolefin and Polyester yarns which shrinks to 1/2 its original diameter, is the ideal way to form the only shrinkable fabric of its kind. The woven construction makes this product extremely flexible and resistant to trapping water, heat and humidity. Provides outstanding abrasion, chafing and cutting protection, even at high temperatures. Cut Cleanly Scissor Material Polyolefin/Polyester Shrinkflex® Fabric tubing, designed primarily to provide mechanical abrasion protection for components such as rubber hoses, plastic pipes, and harness wiring bundles. Also suitable for other applications, such as noise and rattle suppression. Grade H2F Applications: mechanical abrasion protection, severe environment protection, noise and rattle protection, and flexing application. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 VW-1 Colors Available: BK (Black) HEATSHRINK TUBING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet FLAMMABILITY Flammability Rating_____________ Non-Flame-Retardant Lubricating Oil, Antifreeze (50% Ethylene Glycol), Brake Fluid, Engine Oil, Unleaded Gasoline, Diesel Fluid, Hydraulic Fluid, Mineral Hydraulic Fluid, Battery Acid, Water. Measure the Shrinkflex® tubing to length and cut with a scissor. The thickness of your bundle, as well as the desired final appearance, will determine the length of the tubing you cut. Generally, a piece 1 1/2” - 2” long will accommodate almost any need. Single wires, or smaller bundles, require shorter pieces. Slip the Shrinkflex® tubing over the bundle and position it so that both the sleeved and unsleeved portions are sufficiently covered. Notice the small pieces of tubing installed on single wires as part of a color coding system. If your project requires multiple operations, always work up from the smallest to the largest bundle. Maximum Continuous Mil-DTL-23053 275°F (135°C) Minimum Continuous Mil-DTL-23053 -40°F (-40°C) PHYSICAL PROPERTIES Recommended Cutting_____________________ Scissors Stock Colors____________________________________ 1 Wall Type___________________________________ Single Pliancy_______________________________ Very Flexible Abrasion Resistance___________________________ High Gently apply heat to Shrinkflex® tubing from a heat gun, hair dryer or torch with an appropriate attachment. Keep the heat source far enough away so that hot metal or direct flame does not come in contact with the tubing, wires or sleeving. Move the heat around the bundle to prevent damaging the sleeving and to ensure that all areas of the tubing have been shrunk. Once cooled, your installation is complete. © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com CHEMICAL RESISTANCE Shrinks 275°F(135°C)
H2F0.79BK25 价格&库存
很抱歉,暂时无法提供与“H2F0.79BK25”相匹配的价格&库存,您可以联系我们找货
