309-65128
309-65128
    HELLERMAN(海尔曼太通)
309-65128 数据手册
309-65128 Article Number: 309-65128 Heat Shrink Tubing, 4FT-Stick, 2:1, 1/8", 3.2/1.6 dia., Polyolefin, White, 20/pkg Base Data Local Order Number 309-65128 Type TFN21-ST 3.2/1.6 WH Color White (WH) Features and Benefits • Thin, 2 to 1 shrink ratio tubing provides insulation and abrasion protection for wires and cables. • Flammability rating of UL224 VW-1 for use in applications requiring the highest degree of flame protection (excludes clear tubing). • Flexible-yet-durable material resists most common oils, chemicals and fluids. • Available in a variety of diameters and colors for identifying and marking wires and cables. • Available in mini reels, bulk reels, and sticks for small to large volume applications. Product Description TFN21 is a highly flexible thin wall heat shrink tubing with a 2 to 1 shrink ratio and excellent flame retardant properties. In addition to providing insulation and abrasion protection for wires and cables, the polyolefin material also offers resistance to oils, solvents and chemicals. Available in mini reels, bulk reels and sticks, for small to large volume applications. Short Description Heat Shrink Tubing, 4FT-Stick, 2:1, 1/8", 3.2/1.6 dia., Polyolefin, White, 20/pkg Product Dimensions Length L2 (Imperial) 4.0 ft Length L2 (Metric) 1.22 m Printable (Yes/No) Yes Shrink Ratio 2:1 Tensile Strength (MPa) 14 MPa Trade Size 1/8 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 1/8 " Nominal Diameter (Metric) 3.2 mm Wall Thickness WT (Imperial) 0.019 " Wall Thickness WT (Metric) .48 mm Recovered Diameter d (metric) 1.6 mm Recovered Diameter d (imperial) 0.063 " Supplied Diameter D (metric) 3.2 mm Supplied Diameter D (imperial) 0.125 " Logistics and Packaging Quantity Per pack Package Quantity 20 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Dielectric Strength (Metric) 20 kV/mm Elongation at break 600% Flammability UL224 VW-1 Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +275°F (-55°C to +135°C) ROHS Compliant Yes Certification/Specification CSA UL224 125 °C 600V VW-1 UL Recognized (US) Yes © HellermannTyton 2015
309-65128
物料型号:309-65128
器件简介:TFN21是一种高柔性的薄壁热缩套管,具有2:1的收缩比和出色的阻燃性能。除了为电线和电缆提供绝缘和耐磨保护外,聚烯烃材料还具有抗油、溶剂和化学品的特性。
引脚分配:文档中没有提及引脚分配信息。
参数特性: - 收缩比:2:1 - 拉伸强度:14 MPa - 体积电阻率:10^1 Ω·cm - 标称直径:1/8"(3.2 mm) - 壁厚:0.019"(0.48 mm) - 收缩后直径:0.063"(1.6 mm) - 供应直径:3.2 mm(0.125")
功能详解:TFN21热缩套管提供绝缘和耐磨保护,具有阻燃性能,适用于需要最高防火保护的应用场合(不包括透明套管)。材料柔韧耐用,可抵抗大多数常见油脂、化学品和液体。
应用信息:适用于小到大批量应用,可用于识别和标记电线和电缆。
封装信息:材料为交联聚烯烃(PO-X),符合RoHS标准,认证/规格包括CSA和UL224 VW-1。
309-65128 价格&库存
很抱歉,暂时无法提供与“309-65128”相匹配的价格&库存,您可以联系我们找货
