309-65138
309-65138
    HELLERMAN(海尔曼太通)
    HEATSHRINK3/16"X4'WH
309-65138 数据手册
309-65138 Article Number: 309-65138 Heat Shrink Tubing, 4FT-Stick, 2:1, 3/16", 4.8/2.4 dia., Polyolefin, White, 20/pkg Base Data Local Order Number 309-65138 Type TFN21-ST 4.8/2.4 WH Color White (WH) Features and Benefits • Thin, 2 to 1 shrink ratio tubing provides insulation and abrasion protection for wires and cables. • Flammability rating of UL224 VW-1 for use in applications requiring the highest degree of flame protection (excludes clear tubing). • Flexible-yet-durable material resists most common oils, chemicals and fluids. • Available in a variety of diameters and colors for identifying and marking wires and cables. • Available in mini reels, bulk reels, and sticks for small to large volume applications. Product Description TFN21 is a highly flexible thin wall heat shrink tubing with a 2 to 1 shrink ratio and excellent flame retardant properties. In addition to providing insulation and abrasion protection for wires and cables, the polyolefin material also offers resistance to oils, solvents and chemicals. Available in mini reels, bulk reels and sticks, for small to large volume applications. Short Description Heat Shrink Tubing, 4FT-Stick, 2:1, 3/16", 4.8/2.4 dia., Polyolefin, White, 20/pkg Product Dimensions Length L2 (Imperial) 4.0 ft Length L2 (Metric) 1.22 m Printable (Yes/No) Yes Shrink Ratio 2:1 Tensile Strength (MPa) 14 MPa Trade Size 3/16 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 3/16 " Nominal Diameter (Metric) 4.8 mm Wall Thickness WT (Imperial) 0.019 " Wall Thickness WT (Metric) .48 mm Recovered Diameter d (metric) 2.4 mm Recovered Diameter d (imperial) 0.094 " Supplied Diameter D (metric) 4.8 mm Supplied Diameter D (imperial) 0.188 " Logistics and Packaging Quantity Per pack Package Quantity 20 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Dielectric Strength (Metric) 20 kV/mm Elongation at break 600% Flammability UL224 VW-1 Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +275°F (-55°C to +135°C) ROHS Compliant Yes Certification/Specification CSA UL224 125 °C 600V VW-1 UL Recognized (US) Yes © HellermannTyton 2015
309-65138
文档中提及的物料型号为“LM393”,它是一款双运算放大器集成电路。
器件简介指出LM393具有低功耗、低失调电压和高增益带宽积等特点,适用于需要高输入阻抗的模拟信号处理。
引脚分配部分显示了LM393的8个引脚,包括电源、地、输出和输入引脚。
参数特性部分列出了供电电压范围、输入偏置电流、失调电压、增益带宽积等关键参数。
功能详解部分详细介绍了运算放大器的工作原理和应用场景,如模拟信号放大、滤波和比较器。
应用信息部分提供了LM393在各种电子电路设计中的应用示例。
封装信息部分说明了该器件的封装类型和尺寸,便于用户在PCB设计时选择合适的封装。
309-65138 价格&库存
很抱歉,暂时无法提供与“309-65138”相匹配的价格&库存,您可以联系我们找货
