309-65184
309-65184
    HELLERMAN(海尔曼太通)
309-65184 数据手册
309-65184 Article Number: 309-65184 Heat Shrink Tubing, 4FT-Stick, 2:1, 1", 25.4/12.7 dia., Polyolefin, Black, 5/pkg Download spec sheet Base Data Local Order Number 309-65184 Type TFN21-ST-25.4/12.7 BK Color Black (BK) Features and Benefits • Thin, 2 to 1 shrink ratio tubing provides insulation and abrasion protection for wires and cables. • Flammability rating of UL224 VW-1 for use in applications requiring the highest degree of flame protection (excludes clear tubing). • Flexible-yet-durable material resists most common oils, chemicals and fluids. • Available in a variety of diameters and colors for identifying and marking wires and cables. • Available in mini reels, bulk reels, and sticks for small to large volume applications. Product Description TFN21 is a highly flexible thin wall heat shrink tubing with a 2 to 1 shrink ratio and excellent flame retardant properties. In addition to providing insulation and abrasion protection for wires and cables, the polyolefin material also offers resistance to oils, solvents and chemicals. Available in mini reels, bulk reels and sticks, for small to large volume applications. Short Description Heat Shrink Tubing, 4FT-Stick, 2:1, 1", 25.4/12.7 dia., Polyolefin, Black, 5/pkg Product Dimensions Printable (Yes/No) Yes Shrink Ratio 2:1 Tensile Strength (MPa) 14 MPa Trade Size 1 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 1 " Nominal Diameter (Metric) 25.4 mm Wall Thickness WT (Imperial) 0.027 " Wall Thickness WT (Metric) 0.68 mm Recovered Diameter d (metric) 12.7 mm Recovered Diameter d (imperial) 0.5 " Supplied Diameter D (imperial) 0.75 " Supplied Diameter D (metric) 25.4 mm Logistics and Packaging Quantity Per pieces Package Quantity 5 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Dielectric Strength (Metric) 20 kV/mm Elongation at break 600% Flammability UL224 VW-1 Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +275°F (-55°C to +135°C) ROHS Compliant Yes Certification/Specification UL224 125 °C 600V VW-1 CSA UL Recognized (US) Yes © HellermannTyton 2015
309-65184
在PDF文档中,"物料型号"为309-65184,属于HellermannTyton品牌。
这款产品是热收缩套管,具有2:1的收缩比,1英寸直径,25.4/12.7毫米内径,材质为聚烯烃(Polyolefin),颜色为黑色,5个包装销售。
产品特点包括提供绝缘和耐磨保护,具有UL224 VW-1的阻燃等级,适用于需要最高防火要求的应用(不包括透明套管)。
材料柔韧耐用,可抵抗大多数常见油脂、化学品和流体。
提供多种直径和颜色选项,适用于识别和标记电线和电缆。
适用于小到大批量应用,提供迷你卷、大盘卷和棒状包装。
接下来,我将检索“器件简介”、“引脚分配”、“参数特性”、“功能详解”和“应用信息”。
请稍等。
309-65184 价格&库存
很抱歉,暂时无法提供与“309-65184”相匹配的价格&库存,您可以联系我们找货
